Question about the KNX Multitouch module with RTCU 1920 MTN6215-5910
SpaceLogic KNX Forum
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • Question about the KNX Multitouch module with RTCU 1920 MTN6215-5910
Thomas_Rohde
Sisko Thomas_Rohde Sisko
132
Erwin-vd-Zwart
60
Heribert_Dölger
31
SpaceLogic KNX - 4ʺ Touch Unit
KNX Push Button Dynamic Labeling, universal
Wiser for KNX : logic controller
Back to SpaceLogic KNX Forum
Matheuspinheiro
Lieutenant | EcoXpert Master Matheuspinheiro Lieutenant | EcoXpert Master
Posted: ‎2024-05-06 07:31 AM . Last Modified: ‎2024-07-14 11:39 PM
1212
We have hundreds of MTN6215-5910 modules in our building, and some of them are losing their configuration after being turned off and restarted. Do you know if there's any fix that can be applied to correct this issue?
  • Thumbnail of SpaceLogic KNX - 4ʺ Touch Unit
  • Thumbnail of KNX Push Button Dynamic Labeling, universal
  • Thumbnail of Wiser for KNX : logic controller
View products (3)
  • SpaceLYnk
  • Wiser for KNX
Heribert_Dölger
Commander
Posted: ‎2024-06-07 05:09 AM
2
1126
Hello
There is new firmware available. See https://www.se.com/uk/en/download/document/MTN6215_MTN6216-xxxx_firmware/.
Please check the instruction file whether this might help you.
Replies 6
Thomas_Rohde
Sisko
Posted: ‎2024-05-21 06:07 AM
1160
Hello Matheuspinheiro,
can you please provide more information about the devices please?!
Which ETS-Application you are using?
Which HW-Version you have installed?
Please make a startup picture of the screen when disconnect a Multitouch and reconnect after some seconds.
Attention: You need to be quick with the foto as the information screen will last only some seconds!
Kind regards
Thomas
Application Design Engineer
Heribert_Dölger
Commander
2
1127
Hello
Matheuspinheiro
Posted: ‎2024-06-14 01:00 PM
Hello Thomas,
We are using a ETS 5.7.7, ETS Version 14, FW version =  26.1 and FS version = 2.10.
Thanks for helping
Kind regards
Matheus
Matheuspinheiro
Posted: ‎2024-06-14 01:06 PM
1083
Hello Heribert,
Thanks for helping.
I didn't understand the procedures for upgrading. Do I need to use MultitouchUpdater software to update the firmware?
Heribert_Dölger
Commander
Posted: ‎2024-06-17 05:59 AM
Yes correct. FW update can only be done with Multitouch Pro updater tool.
Thomas_Rohde
Sisko
Posted: ‎2024-06-17 06:09 AM
in the manual (you can find with the link below), starting on page 143, is the process better described I think.
https://download.schneider-electric.com/files?p_Doc_Ref=MTN621x-0310_5910_SW_EN&p_enDocType=System+u...
Please let us know when you still have problems.
Kind regards
Thomas
