Orientation light car park script hL/sL
SpaceLogic KNX Forum
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • Orientation light car park script hL/sL
Thomas_Rohde
Sisko Thomas_Rohde Sisko
132
Erwin-vd-Zwart
60
Heribert_Dölger
31
SpaceLogic KNX - 4ʺ Touch Unit
KNX Push Button Dynamic Labeling, universal
Wiser for KNX : logic controller
Back to SpaceLogic KNX Forum
sesa264057_brid
sesa264057_brid Schneider Alumni (Retired)
Posted: ‎2016-12-07 12:08 AM . Last Modified: ‎2024-07-14 11:54 PM
566
Is there anybody that have a script for this function?
  • Thumbnail of SpaceLogic KNX - 4ʺ Touch Unit
  • Thumbnail of KNX Push Button Dynamic Labeling, universal
  • Thumbnail of Wiser for KNX : logic controller
View products (3)
Erwin-vd-Zwart
Janeway
Posted: ‎2016-12-13 05:30 AM
Hi Martin,
I think you can easily do this with a extra object (or can also be by storage), now done by extra byte object, also easy to see what next rotation value will be (;
Script would look like this: (link it as event based to the object controlled by the binary input)
address_line_1 = '14/0/0' -- bit object
address_line_2 = '14/0/1' -- bit object
address_line_3 = '14/0/2' -- bit object
address_rotation = '14/0/3' -- byte object
value_line_1 = grp.getvalue(address_line_1)
value_line_2 = grp.getvalue(address_line_2)
value_line_3 = grp.getvalue(address_line_3)
value = event.getvalue()
if value == true then
  value_rotation =  grp.getvalue(address_rotation)
  if value_rotation == 0 then
       if value_line_1 == false then
            grp.write(address_line_1, true)
       end
       if value_line_2 == true then
            grp.write(address_line_2, false)
       end
       if value_line_3 == true then
            grp.write(address_line_3, false)
       end
       grp.update(address_rotation, 1 )
  elseif value_rotation == 1 then
       if value_line_1 == true then
            grp.write(address_line_1, false)
       end
       if value_line_2 == false then
            grp.write(address_line_2, true)
       end
       end
       grp.update(address_rotation, 2)
  elseif value_rotation == 2 or value_rotation > 2 then
       end
       end
       if value_line_3 == false then
            grp.write(address_line_3, true)
       end
       grp.update(address_rotation, 0)
  end
else
  end
  end
  end
end
Best regards,
Erwin van der Zwart
sesa264057_brid
Posted: ‎2016-12-13 06:11 AM
Thanks Erwin,
it works great.
