InSide control
SpaceLogic KNX Forum
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • InSide control
Thomas_Rohde
Sisko Thomas_Rohde Sisko
132
Erwin-vd-Zwart
60
Heribert_Dölger
31
SpaceLogic KNX - 4ʺ Touch Unit
KNX Push Button Dynamic Labeling, universal
Wiser for KNX : logic controller
Back to SpaceLogic KNX Forum
sesa432464
sesa432464 Schneider Alumni (Retired)
Posted: ‎2016-11-20 02:27 AM . Last Modified: ‎2024-07-14 11:54 PM
718
InSide control
I am trying to connect an Ipad to KNX Inside control IP-gateway using the inside control app but whenever i try to do so this message appears
"KNX connection error.....You are trying to connect to a different MAC address or the IP gateway is not the indicated model"  and this when I activate the auto discover .... but when I do not activate the auto discover and assign the IP of the KNX Inside control IP-gateway the message is "KNX connection error.... impossible to connect to the KNX installation " !!!!
  • Thumbnail of SpaceLogic KNX - 4ʺ Touch Unit
  • Thumbnail of KNX Push Button Dynamic Labeling, universal
  • Thumbnail of Wiser for KNX : logic controller
View products (3)
Heribert_Dölger
Commander
Posted: ‎2016-11-25 07:10 AM
1
644
Hello
There are several possibilities why you don't get connection.
Either you have entered no or a wrong MAC address in the configuration tool (InSideControl Builder).
Or there are several InSideControl gateways or KNX IP routers in your IP network. If this is the case you should try to power off all other KNX IP devices or disconnect them from the IP network.
Best regards
Heribert
Erwin-vd-Zwart
Janeway
Posted: ‎2016-12-03 01:47 AM
What also might help is to turn off auto discovery in the APP settings.
Don't ask me why (i think it depends on other devices in your IT network) but i have seen this multiple times as the solution.
BR,
Erwin van der Zwart
