We Value Your Feedback!
MTN 6215-5910 error 04, can't upgrade firmware
SpaceLogic KNX Forum
Schneider Electric SpaceLogic KNX forum to get support and share knowledge including selection, installation and troubleshooting for spaceLYnk, Wiser for KNX, eConfigure KNX, SpaceLogic KNX Hybrid module and other topics.
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • Re: MTN 6215-5910 error 04, can't upgrade firmware
Thomas_Rohde
Sisko Thomas_Rohde Sisko
123
Erwin-vd-Zwart
Sisko Erwin-vd-Zwart Sisko
54
Heribert_Dölger
Lt. Commander Heribert_Dölger Lt. Commander
30
FZetina
Lt. Commander FZetina Lt. Commander
27
Back to SpaceLogic KNX Forum
Jonass
Crewman Jonass
Posted: ‎2024-10-27 12:59 PM . Last Modified: ‎2024-10-27 01:08 PM
555
Hello
Have been getting for years an error04 on one off our MTN-6215-5910 devices and need to program device adress over and over. Saw there's a "recent" update due to a possbile fault that destroys memroy (finally, tried when it first arrived to contact support but they dissmissed it (out of warranty)). Been trying to update firmware but no sucess. Multi touch updater won't recognize the device is in update mode, it goes in to normal usb mode no problem.
Do I have to recognize defeat and throw it in the bin or is there some solution still.
  • SpaceLogic devices
Replies 4
Cristiano_Carli_Ballola
Lt. Commander Cristiano_Carli_Ballola Lt. Commander
Posted: ‎2024-10-28 02:33 AM
Hello Jonas,
have you enabled this parameter?
"Start button for firmware update"
This activate the update button on the MT screen.
You have to press and hold it until the screen turns to black.
Then, you should be able to proceed with the firmware update process
Heribert_Dölger
Posted: ‎2024-10-28 03:04 AM
518
Most probably you haven't installed the driver. After installation of the update tool (you need version V2) you will find the drivers in the following folder:
C:\Program Files (x86)\Schneider Electric\Multitouch Pro Update\MultitouchProDriver.zip\Driver
Select the folder according your Windows version (use WIN10 if higher version) and install the driver (+.exe file).
Jonass
Crewman Jonass
Posted: ‎2024-11-14 11:42 AM
This worked, thanks. Lets hope it also will solve the isssue.
The citeria for the problem matches a 100%
Ps, it was nearly impssoible to find the updater tool. Finally found it on an old Merten site. Non of the site SE is geo forcing (so stupid) me on had it and it wasn't provided with the buletin package.
Heribert_Dölger
Posted: ‎2024-11-15 01:59 AM
Hello Jonass
Happy to hear that the update tool is working now.
And many thanks for the hint about the missing of the tool on website. I have informed the responsible people about this.
This is a heading
