mtn6215-0410 window contact
SpaceLogic KNX Forum
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • mtn6215-0410 window contact
Thomas_Rohde
Sisko Thomas_Rohde Sisko
132
Erwin-vd-Zwart
60
Heribert_Dölger
31
Back to SpaceLogic KNX Forum
Therang
Crewman Therang
Crewman
Posted: ‎2024-11-07 03:44 PM
799
I have several mtn6215-0410  that is connectet to window contact on object 163
Open window makes it go in frost protection
But when window closes it gets stuck in frost protection
  • SpaceLogic devices
Therang
Crewman Therang
Crewman
Posted: ‎2024-11-12 01:52 AM
Thank you for your answer
We have done a logic now, so its working
Kind regards
Tom
Thomas_Rohde
Sisko
Posted: ‎2024-11-11 06:50 AM
753
Hello Therang!
It seems you are correct with your findings!
I will report the bug towards our R&D so that it get fixed in one of the next updates.
Do you have a W4K (LSS100100) or a sL (LSS100200) within your installation?
If so, you could create an event script on the GA of the window contact which stores the current operation mode when the windows opens. When the window closes you sent the stored operation mode.
Kind regards
Thomas
Application Design Engineer
IC_Systems
Captain IC_Systems
Captain
Posted: ‎2024-11-12 12:01 AM . Last Modified: ‎2024-11-12 12:02 AM
SL is the magic tool
I think its not completely a bug, its could be logically true. but R&D could add another filed to control the mode for close window.
but honestly this TS is much better than the previous multitouch 🙂
Best Regards,
Therang
Crewman Therang
Crewman
Kind regards
Tom
