On/off function for the thermostat widget did not appear in the Wiser KNX App
SpaceLogic KNX Forum
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • On/off function for the thermostat widget did not appear in the Wiser KNX App
Thomas_Rohde
Sisko Thomas_Rohde Sisko
132
Erwin-vd-Zwart
60
Heribert_Dölger
31
Back to SpaceLogic KNX Forum
IC_Systems
Captain IC_Systems
Captain
Posted: ‎2024-09-04 06:27 AM . Last Modified: ‎2024-09-04 06:29 AM
5
1256
hello Dears,
I used the Built in Thermostat widget, In touch it has an on/off Icon and working well, but in the Wiser for KNX Mobile App it didn't appear.
Currently, I’m using a separate on/off function, but it would be ideal to have the on/off feature integrated within the thermostat itself. Is this normal, or should it be visible in the app’s thermostat widget? If so, how can I make it appear there?
Best Regards,
  • Local App
  • Wiser for KNX
FZetina
Commander FZetina Commander
Commander
Posted: ‎2024-09-17 09:53 AM
1
1139
Hi
Also in the next release (end of Sept/Beginning of October) this should be fixed and now the Thermostat should be able to show the on/off button in the App too. This week the team should test all functionality so we can start field test right after. And then release it to production.
Fernando
Fernando Zetina
Replies 5
Thomas_Rohde
Sisko
Posted: ‎2024-09-16 01:38 AM
1
1171
Hello IC-Systems,
Many THANKS for the hint. I forwarded your topic to our R&D.
Kind regards
Thomas
Application Design Engineer
IC_Systems
Captain IC_Systems
Captain
Posted: ‎2024-09-17 12:14 AM
Thank you @Thomas_Rohde
I attempted to create a custom widget for use in the Wiser app but was unfortunately unsuccessful. If it is possible to create a custom widget for the mobile app, I would appreciate it if you could share the process.
Best Regards,
FZetina
Commander
1
1140
Hi
Fernando
Fernando Zetina
IC_Systems
Captain IC_Systems
Captain
Posted: ‎2024-10-28 01:33 AM . Last Modified: ‎2024-10-28 05:22 AM
Hello Dears,
could you please add more options to the setpoint step.
I have a project where the setpoint step is 1 °C not 0.1 nor 0.5
while this will make some conflict in the control.
Best Regards,
Luis_Silva.
Luis_Silva.
Cadet
Posted: ‎2024-11-18 08:24 AM
Did the update already release with this function?
Luis Silva
