Does the Wiser LSS100100 running V3 support VPN tunnel termination ?
SpaceLogic KNX Forum
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • Does the Wiser LSS100100 running V3 support VPN tunnel termination ?
Thomas_Rohde
Sisko Thomas_Rohde Sisko
132
Erwin-vd-Zwart
60
Heribert_Dölger
31
Back to SpaceLogic KNX Forum
KVermeylen
Crewman KVermeylen
Crewman
Posted: ‎2024-11-11 02:07 PM
735
I would like to terminate a VPN tunnel straight on the LSS100100 device to make KNX configuration changes via ETS6.
Is that supported?
If not is there an alternative way (except from port forwarding) to be able to deploy/configure KNX devices over the internet via the LSS100100?
Many thanks,
Kurt Vermeylen
  • Wiser for KNX
Tags (9)
  • ets
  • IPSEC
  • knx
  • lss100100
  • remote access
  • vpn
  • wiser
  • Wiser KNX
Thomas_Rohde
Sisko
Posted: ‎2024-11-19 01:09 AM
Hello KVermeylen!
To "I would like to terminate a VPN tunnel straight on the LSS100100 device to make KNX configuration changes via ETS6."
No, this is not supported yet.
Alternative could be that you place your own little network on customer side which you can reach via VPN.
Kind regards
Thomas
Application Design Engineer
Thomas_Rohde
Sisko
Hello KVermeylen!
Kind regards
Thomas
