LSS100100 only show a permanently red light - HW 1.xx.
SpaceLogic KNX Forum
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • LSS100100 only show a permanently red light - HW 1.xx.
Thomas_Rohde
Sisko Thomas_Rohde Sisko
128
Erwin-vd-Zwart
Sisko Erwin-vd-Zwart Sisko
56
Heribert_Dölger
Lt. Commander Heribert_Dölger Lt. Commander
30
FZetina
Lt. Commander FZetina Lt. Commander
29
Back to SpaceLogic KNX Forum
Vico
Vico
Cadet
Posted: ‎2025-08-10 05:31 AM
206
I have a Homelink, Wiser LSS100100 HW 1.xx.
This device was working perfectly, but for the past month, a red light has been permanently lit inside, near the micro SD card.
Only once or twice did one of the two green lights on the top left of the device light up.
When I ping it, the device is red, but it does not show any ARP requests.
Can anyone tell me what is wrong with it, if there is a solution, and why this has happened?
Vico
  • Wiser for KNX
Replies 5
LadislavS
Crewman LadislavS Crewman
Crewman
Posted: ‎2025-08-12 11:09 PM
192
Hello Vico,
thank you for your post. I will try to contract our development team and check with them. I will try to come back to you ASAP.
Have a nice day.
Ladik
Ladislav Sustek
Product Owner End User Software
Vico
Vico
Cadet
Posted: ‎2025-08-15 11:04 AM
Ok, thank you
I remain then on standby.
Best regards.
Víctor
Thomas_Rohde
Sisko
Posted: ‎2025-08-27 01:05 AM
119
Hi Vico!
Sorry for the late reply!
Can you reach still the device?
And if so ... what is the dedicated level of CPU-Load?
And in any case I would try to make a backup!
If you cant reach the W4K at all or only partly then it could indicate that the SD-Card is dying.
Kind regards
Thomas
Application Design Engineer
Vico
Vico
Cadet
Posted: ‎2025-08-28 04:14 AM
110
Dear Thomas,
Thank you very much for your attention.
I don't have access to the device.
I tried to create an SD card and load a backup I have, but I haven't been able to do so.
Could you tell me the correct steps, please, and the recommended size for the SD card?
Kind regards,
Vico
esteve_budia
Lieutenant esteve_budia Lieutenant
Lieutenant
Posted: ‎2025-08-28 11:05 PM
Can you try to follow the steps on this guide?
LSS100100 HW1 in your case
https://www.se.com/es/es/download/document/AN2_001/
