4" touch panel MTN6215-0410 along with FCA MTN645094
SpaceLogic KNX Forum
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • 4" touch panel MTN6215-0410 along with FCA MTN645094
Thomas_Rohde
Sisko Thomas_Rohde Sisko
131
Erwin-vd-Zwart
59
Heribert_Dölger
31
FZetina
Commander FZetina Commander
29
Back to SpaceLogic KNX Forum
Aya.ahmed
Crewman Aya.ahmed
Crewman
Posted: ‎2025-08-13 09:35 AM
224
Dears,
We're currently trying to prepare an ETS program to control FCA (MTN645094) using 4" touch screen (MTN6215-0410) in both heating and cooling modes, but we can't get it to work.
When choosing "Room temperature control", the fan icon has 5 modes (Off/ speed1/2/3/Auto) as per photo and going through the available parameters there is no option to remove the off mode.Fan off pic.jpg
Although all seems to be working fine, we need to remove the off option from the fan so that the valve does not operate while the fan is off especially that there is a heater connected to FCA.
I am attaching the ETS file, if you can give us your insights.
Thanks in advance
Triumph FCU Test Scene (2) 13.8.2025 .zip
  • SpaceLogic devices
Thomas_Rohde
Sisko
Posted: ‎2025-08-27 12:31 AM
Hello Aya.ahmed!
There is currently no option to hide the ON/OFF button.
This will be fixed with the next update.
Workaround could be that you place a certain logic behind the dedicated group address.
Means, all the time when it is getting switched OFF by user interaction the logic will switch in ON again.
Kind regards
Thomas
Application Design Engineer
Aya.ahmed
Crewman Aya.ahmed
Crewman
Posted: ‎2025-08-28 04:30 AM
Thanks Thomas ... much appreciated.
We'll try some workarounds, one of which is to switch the valves off when the fan is off.
