Knx Spacelogic programming with W4KNX / Spacelynk
SpaceLogic KNX Forum
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • Knx Spacelogic programming with W4KNX / Spacelynk
Thomas_Rohde
Sisko Thomas_Rohde Sisko
132
Erwin-vd-Zwart
60
Heribert_Dölger
31
SpaceLogic KNX - 4ʺ Touch Unit
KNX Push Button Dynamic Labeling, universal
Wiser for KNX : logic controller
Back to SpaceLogic KNX Forum
domotiqa
Lt. Commander domotiqa
Lt. Commander
Posted: ‎2021-09-16 12:55 AM . Last Modified: ‎2024-07-14 11:46 PM
1511
Hello, I have lots of issue on several customer site to program the MTN6705-0008 for example with the Spacelynk or Homelynk KNX Ip interface. It's very often buging to 50% then stop programming due to not respons. No problem with older device
If I retry with my Spacelogic USB interface no problem.
I try 2.6,2.6.1,2.6.2 all same !!
Big problem for our remote customer
Smarthome & Smartbuilding Expert
  • Thumbnail of SpaceLogic KNX - 4ʺ Touch Unit
  • Thumbnail of KNX Push Button Dynamic Labeling, universal
  • Thumbnail of Wiser for KNX : logic controller
View products (3)
  • SpaceLYnk
  • Wiser for KNX
David_Navratil
Lt. Commander David_Navratil Lt. Commander
Lt. Commander
Posted: ‎2021-10-13 01:49 AM
1480
Based on the KNX project you send me where there were more than 200 devices at one KNX line I can tell that KNX TP probably is not able to handle such big traffic during download. The position of the W4KNX/sL at the line is probably what is the main reason why the USB interface is working (that you have next to the device).
We have performed tests in our installation and all of the downloads were performed without any issues.
Regards
David
Replies 6
PetrMares
Commander PetrMares Commander
Commander
Posted: ‎2021-09-17 12:40 AM
5
1504
thank you for report. I am going to bring to attention of support. We have a device MTN6705-0008 in place so try to reproduce.
Can you share version of ETS and ideally project at least with configuration of our device MTN6705-0008?
Out of this we do not register such case.
domotiqa
Lt. Commander
Posted: ‎2021-09-17 01:59 AM
1501
ok Ptr, I send you private link !
Thank
PetrMares
Commander
Posted: ‎2021-09-17 02:11 AM
3
1498
received and support has been informed. He will take this point with you.
domotiqa
Lt. Commander
Posted: ‎2021-09-21 04:41 AM
1494
I have this problem often  and at least I remember two project where impossible to program it without a Usb interface (SL and hl useless)
David_Navratil
Lt. Commander
1481
Regards
David
domotiqa
Lt. Commander
Posted: ‎2021-10-13 02:09 AM
This project has repeater and powersupply.
The problem is that I have this issue on other project too. At least two of them.
And when using the Usb interface, no problem.
Is there setup on SL that is more safe like priority, message in queue...
