KNX communication
SpaceLogic KNX Forum
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • KNX communication
Thomas_Rohde
Sisko Thomas_Rohde Sisko
132
Erwin-vd-Zwart
60
Heribert_Dölger
31
SpaceLogic KNX - 4ʺ Touch Unit
KNX Push Button Dynamic Labeling, universal
Wiser for KNX : logic controller
Back to SpaceLogic KNX Forum
AmrMustafa
Ensign AmrMustafa
Ensign
Posted: ‎2022-02-01 05:13 AM . Last Modified: ‎2024-07-14 11:45 PM
4
1268
KNX communication
Hi
I have 35 panels on every 35 floor
every panel has a KNX product And Connect with KNX field devices and every panel Has (wiser 100100)
each panel connected separately with the product on the same floor and each Wiser 100100 connected to the nearest datapoint
how can I control and see all 35 Panels in this case?
if I changed the topology of knx Bus can I use wiser 100100 as an IP router Gateway or not? if yes (HOW?)
if anyone has a solution please advise me?
  • Thumbnail of SpaceLogic KNX - 4ʺ Touch Unit
  • Thumbnail of KNX Push Button Dynamic Labeling, universal
  • Thumbnail of Wiser for KNX : logic controller
View products (3)
Thomas_Rohde
Sisko
Posted: ‎2022-02-03 02:32 AM . Last Modified: ‎2022-02-03 02:34 AM
1237
Hello AmrMustafa,
To "if I connected all of panel to internet ( how much conflict between Group address for each panel )"
I guess that all floors have the same structure and does not need to communicate to each other from KNX-Point of view.
If this is the case then you can select "TP-UART". If you are fully sure that you didnt want any KNX-IP-Features (use it as an interface) then you can untick the dedicated parameter.
can simply deactivate the KNX-Communication on IP-Side. Means each KNX-Communicationstays on the dedicated level/floor.
If this is set you can still have the W4K connected to the internet to get for example the actual time which is needed for sunrise/sunset features.
To "I ask if I want to  control all panels from 1 workstation  how that ?"
You can create, just as one example, in the first W4K a custom visualization where you can integrate all 34 views of the TouchVisu. For that you need to create the dedicated structure to navigate between the different floors.
Each W4K (of each floor) needs to be included in a dedicated "Frame". Here you enter the dedicated URL of the TouchVisu of each W4K within the building.
Here you find the link to the dedicated manual to review all instructions more in detail.
https://download.schneider-electric.com/files?p_enDocType=User+guide&p_File_Name=Wiser+for+KNX+%28LS...
Kind regards
Thomas
Application Design Engineer
Thomas_Rohde
Sisko
Posted: ‎2022-02-03 02:36 AM
This picture belongs to the threat above within the section with the "Frame".
For some reasons I couldnt add it there.
sorry for that
Kind regards
Thomas
Replies 4
Thomas_Rohde
Sisko
Posted: ‎2022-02-02 01:51 AM
1248
Hello AmrMustafa,
to "how can I control and see all 35 Panels in this case?"
I am not sure that I get this question fully. Normally, when all W4K are connected to a network than you could control all of them by entering the dedicated IP of W4K to reach the visu?! Please be more specific.
to "if I changed the topology of knx Bus can I use wiser 100100 as an IP router Gateway or not?"
Means you have currently a KNX Backbone with line coupler and you are thinking to change to an IP-Backbone?
Is it that what you are looking for?
Kind regards
Thomas
AmrMustafa
Ensign AmrMustafa
Ensign
Posted: ‎2022-02-02 04:28 AM
1245
Hi,Thomas
No, no line coupler & no bus coupler it is just only LS100100
all 34 panel contain ( powersupply , actuator , sensor , wiser ls100100) for one floor
is there another way ?
Thomas_Rohde
Sisko
1238
Hello AmrMustafa,
Kind regards
Thomas
Thomas_Rohde
Sisko
sorry for that
Kind regards
Thomas
