Slow loading of spacelynk
SpaceLogic KNX Forum
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • Slow loading of spacelynk
Thomas_Rohde
Sisko Thomas_Rohde Sisko
132
Erwin-vd-Zwart
60
Heribert_Dölger
31
SpaceLogic KNX - 4ʺ Touch Unit
KNX Push Button Dynamic Labeling, universal
Wiser for KNX : logic controller
Back to SpaceLogic KNX Forum
Posted: ‎2022-02-01 06:09 AM . Last Modified: ‎2024-07-14 11:45 PM
4
1802
Hi
I have SpaceLynk LSS100200 and I have a small program with the widget in it. I use the touch option in this device with no background but opening the touch option is too slow it takes about a minute to show widgets ..etc and with background, it gets slower. anyone here has a solution for it? also, what is the best size and resolution for the background image?
  • Thumbnail of SpaceLogic KNX - 4ʺ Touch Unit
  • Thumbnail of KNX Push Button Dynamic Labeling, universal
  • Thumbnail of Wiser for KNX : logic controller
View products (3)
Tags (3)
  • knx
  • spacelynk
David_Navratil
Lt. Commander David_Navratil Lt. Commander
Lt. Commander
Posted: ‎2022-02-03 02:49 AM
1
1770
Hello Shamaa,
I have restored the project and in my installation, it works perfectly. Loading of the Touch 3 app is less than 5 sec, loading of each room in the Touch visualization is instant.
In your case seems to be that problem is related to the specific installation, which means you can have high KNX traffic. High CPU load or peaks. Can you provide us with the picture of the CPU load (right-bottom corner in the configurator), and KNX traffic Configurator->Utilities->System->Network->KNX statistics
Thank you
David
Replies 4
Thomas_Rohde
Sisko
Posted: ‎2022-02-02 01:43 AM
3
1781
Hello Shamaa,
it is not easy to answer this without having more details.
Can you share the project backup so that we can analyse your config more in detail?
Kind regards
Thomas
Application Design Engineer
Posted: ‎2022-02-02 11:31 PM
1775
Thank you so much for your answer.
All files are attached herewith.
https://drive.google.com/drive/folders/1V1U71Kr7c5xg0HKXbAcNeG1Y-ZYutv8_?usp=sharing
It would be much appreciated to help us :).
David_Navratil
Lt. Commander
1
1771
Hello Shamaa,
Thank you
David
Posted: ‎2022-02-03 03:00 AM
You are totally right, I have just figured out the problem. CPU load was about 5.0!! I fixed the issue and now it is not more than 0.6
Thank you so much for helping.
