MTN6503-0201 configuration for A9XMSB11 (replacement for SIM10M modules)
SpaceLogic KNX Forum
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • MTN6503-0201 configuration for A9XMSB11 (replacement for SIM10M modules)
Thomas_Rohde
Sisko Thomas_Rohde Sisko
132
Erwin-vd-Zwart
60
Heribert_Dölger
31
SpaceLogic KNX - 4ʺ Touch Unit
KNX Push Button Dynamic Labeling, universal
Wiser for KNX : logic controller
Back to SpaceLogic KNX Forum
PiotrJakubczyk
Sisko PiotrJakubczyk Sisko
Sisko
Posted: ‎2022-01-03 01:48 AM . Last Modified: ‎2024-07-14 11:45 PM
466
Hello
Because SIM10M modules seems to be not available ... i want to propose to client A9XMSB11  as replacement for measurement of water pulse meter.
1)Does anyone have information how to configure KNX Metering Gateway Modbus REG-K ( MTN6503-0201 )  for  Acti9 Smartlink - Modbus RS485 slave - smart communication I/O module  ( A9XMSB11 ). Or maybe i should choose SIM10M template?
2) ..or anyone can state it will work reading actual values from A9XMSB11 (in my case i have to access actual value of used water from pulse counters inside A9XMSB11)
3) Is my understanding is good?: All officially supported devices for MTN6503-0201 are available as device templates, anything else would not be supported.
  • Thumbnail of SpaceLogic KNX - 4ʺ Touch Unit
  • Thumbnail of KNX Push Button Dynamic Labeling, universal
  • Thumbnail of Wiser for KNX : logic controller
View products (3)
  • Protocols
Heribert_Dölger
Commander
Posted: ‎2022-01-27 06:52 AM
Next to the templates, KNX Metering Gateway allows direct access to Modbus registers. Up to 40 register addresses can be read. You can configure it in ETS application, tab "Direct access to Modbus register".
Heribert_Dölger
Commander
