Issue with system mode in new AirOne controller widget
SpaceLogic KNX Forum
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • Issue with system mode in new AirOne controller widget
Thomas_Rohde
Sisko Thomas_Rohde Sisko
132
Erwin-vd-Zwart
60
Heribert_Dölger
31
Back to SpaceLogic KNX Forum
electrokinisi1_
Ensign electrokinisi1_
Ensign
Posted: ‎2025-08-21 08:09 AM
733
I am currently testing the new widget for controlling the AirOne controller and I am facing an issue with the system mode.
The controller outputs a communication object with 1 byte DTP 20.105, but the widget does not seem to accept it. I noticed that it only accepts DTP 5.001.
Am I doing something wrong, or is this a compatibility limitation?
Thank you in advance for your support.
  • Wiser for KNX
Replies 9
Thomas_Rohde
Sisko
Posted: ‎2025-08-26 12:28 AM
Hello electrokinisi1_!
Can you please be more specific in the widget you have used?
Do you mean the Airzone Controller widget?
Kind regards
Thomas
Application Design Engineer
Erwin-vd-Zwart
Janeway
Posted: ‎2025-08-26 11:44 PM
Have you tried to just change the byte object from 20 to 5? For the widget it does not matter, a byte is a byte value..
electrokinisi1_
Ensign
Posted: ‎2025-08-31 11:11 PM
Hi ok i changed and it worked thank you very match .
But I see that the widget  does not appear in the mobile application via cloud, why?
Erwin-vd-Zwart
Janeway
Posted: ‎2025-08-31 11:17 PM
@electrokinisi1_
What widget do you use? Either the widget is not app compatible, it should be listed under this section:
If it is under the "App compatible" widgets then it must be misconfigured ..
electrokinisi1_
Ensign
Posted: ‎2025-08-31 11:39 PM
Yes, I agree, but as you will see in the settings, it does not have the corresponding option.
electrokinisi1_
Ensign
Posted: ‎2025-08-31 11:40 PM
I use widget Airzone
Erwin-vd-Zwart
Janeway
Posted: ‎2025-09-01 12:03 AM
639
@electrokinisi1_
Just tried to add one to my visu, got same behavior so this seems to be a bug..
@Thomas_Rohde Could you verify this?
electrokinisi1_
Ensign
Posted: ‎2025-09-01 12:11 AM
Yes, what do you want me to do?
Thomas_Rohde
Sisko
Posted: ‎2025-09-01 06:07 AM
Dear both,
I double checked with R&D and it is clearly a bug which needs to be corrected.
Many THANKS for the hint/feedback!
Kind regards
Thomas
