Issue loading projects with firmware version 3.0.0
SpaceLogic KNX Forum
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • Issue loading projects with firmware version 3.0.0
Thomas_Rohde
Sisko Thomas_Rohde Sisko
132
Erwin-vd-Zwart
60
Heribert_Dölger
31
SpaceLogic KNX - 4ʺ Touch Unit
KNX Push Button Dynamic Labeling, universal
Wiser for KNX : logic controller
Back to SpaceLogic KNX Forum
Atalanta
Crewman Atalanta Crewman
Crewman
Posted: ‎2024-01-17 07:40 AM . Last Modified: ‎2024-07-14 11:41 PM
1550
I created some projects in a spaceLYnk with firmware version 2.7.0, I took a back up of these projects and am now trying load them onto a spaceLYnk that has firmware version 3.0.0 but the objects and visualisations wont load at all. I've tried removing all the scripts before uploading but am experiencing the same issue.
Are there any other things that could interfere with the changes to the firmware?
  • Thumbnail of SpaceLogic KNX - 4ʺ Touch Unit
  • Thumbnail of KNX Push Button Dynamic Labeling, universal
  • Thumbnail of Wiser for KNX : logic controller
View products (3)
  • SpaceLYnk
Thomas_Rohde
Sisko
Posted: ‎2024-01-19 01:56 AM
Hello Atalanta,
would you mind to share the dedicated project-backup with us?!
In case you dont mind. Please share with us in detail what you are missing to understand if it is on our side the same problem.
Kind regards
Thomas
Application Design Engineer
Replies 6
domotiqa
Lt. Commander domotiqa
Lt. Commander
Posted: ‎2024-01-18 02:43 AM
I think I will not try yet to upgrade. first for a V3 don't look much upgrade functionnality.
Always bug on first "major" update.
Looks like it s more to secure/close the system (more restriction since 2.6.2 firmware) but no improvment...
Smarthome & Smartbuilding Expert
Thomas_Rohde
Sisko
Hello Atalanta,
Kind regards
Thomas
Atalanta
Crewman
Posted: ‎2024-01-25 01:09 AM
Good morning,
I will need to check if I am able to share the project back up.
The issue is that when I load the project back up, none of the visualisations I've created are imported and neither are any of the objects.
I've also had some issues with icons and text disappearing when I try and alter them on firmware version 2.8
Thomas_Rohde
Sisko
Posted: ‎2024-03-13 06:08 AM
Hello Atalanta,
Any update? Without the backup or further information (like a video) it is pretty hard to help.
Kind regards
Thomas
Neskettani
Administrator Neskettani Administrator
Posted: ‎2024-10-09 07:20 AM
1048
Hello @Atalanta  have you found a solution to your problem?
Nesrine Kettani
Marketing owner of Digital Energy Community
Atalanta
Crewman
Posted: ‎2024-10-09 07:49 AM
Hiya, I sent the back up to Schneider Electric Advanced Technical Support and was told that there was a problem with the database but that it would be fixed when using FW v3.1.0. They were able to produce a backup that gets around the issue to use with FW v3.0.0 as a placeholder.
