Integration with Somfy RS485 RTS WIRELESS MOTOR CONTROLLER
SpaceLogic KNX Forum
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • Integration with Somfy RS485 RTS WIRELESS MOTOR CONTROLLER
Thomas_Rohde
Sisko Thomas_Rohde Sisko
132
Erwin-vd-Zwart
60
Heribert_Dölger
31
SpaceLogic KNX - 4ʺ Touch Unit
KNX Push Button Dynamic Labeling, universal
Wiser for KNX : logic controller
Back to SpaceLogic KNX Forum
IC_Systems
Captain IC_Systems
Captain
Posted: ‎2021-04-26 06:40 AM . Last Modified: ‎2024-07-14 11:47 PM
2080
Hello
it's known that SE and Somfy have a partnership.
I was asked if this Controller from Somfy could be connected to the SE KNX system using SL or Wiser for KNX.
Attached datasheet
Best Regards,
Best Regards,
  • Thumbnail of SpaceLogic KNX - 4ʺ Touch Unit
  • Thumbnail of KNX Push Button Dynamic Labeling, universal
  • Thumbnail of Wiser for KNX : logic controller
View products (3)
  • Scripts
  • SpaceLYnk
  • Wiser for KNX
Thomas_Rohde
Sisko
Posted: ‎2021-05-06 06:56 AM
1
2075
Hello nasser_ic-syste,
we havent had the chance to use/test this device to be able to confirm that it is working or not.
The sentence out of the manual "sounds" promising:
"This controller can be seamessly integrated into any control system
available, including Control4, Crestron, HAI, BitWise, AMX, Elan g!
and any other with RS485 or RS232 dedicated serial ports."
Would you be able to provide a test environment (controller plus a connected motor)?
Kind regards
Thomas
Application Design Engineer
Thomas_Rohde
Sisko
1
2076
Kind regards
Thomas
IC_Systems
Captain IC_Systems
Captain
Posted: ‎2021-05-17 03:09 AM
Hello @Thomas_Rohde
Yeah, we have a Project with these controllers and Motors.
But also Control4 present in this project, So they take the chance to test on-site
I know that it's possible from SL side to make the integration using RS485 and Scripting, but I don't know if it more easily from the Control4 side
I will keep you in touch with updates
Best Regards,
