Animate icons in Wiser for KNX/Homelynk/Spacelynk in "Touch view"
SpaceLogic KNX Forum
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • Animate icons in Wiser for KNX/Homelynk/Spacelynk in "Touch view"
Thomas_Rohde
Sisko Thomas_Rohde Sisko
132
Erwin-vd-Zwart
60
Heribert_Dölger
31
SpaceLogic KNX - 4ʺ Touch Unit
KNX Push Button Dynamic Labeling, universal
Wiser for KNX : logic controller
Back to SpaceLogic KNX Forum
vicbac
Ensign vicbac
Ensign
Posted: ‎2021-01-01 03:59 PM . Last Modified: ‎2024-07-14 11:47 PM
5
2320
Is there possible to use custom CSS to spin and animate icons in Wiser for KNX/Homelynk/Spacelynk in "Touch view"
In PC view it works fine but I wonder if it is possible to get this function in the new Touch by custom CSS? How to link this with an object?
@Erwin-vd-Zwart Is this something you know is possible?
  • Thumbnail of SpaceLogic KNX - 4ʺ Touch Unit
  • Thumbnail of KNX Push Button Dynamic Labeling, universal
  • Thumbnail of Wiser for KNX : logic controller
View products (3)
Tags (5)
  • homelynk
  • knx
  • spacelynk
  • wiser for knx
Replies 5
Erwin-vd-Zwart
Janeway
Posted: ‎2021-01-01 08:38 PM . Last Modified: ‎2021-01-01 08:51 PM
2310
Custom CSS and Custom JS are only applied on the PC/Tablet and Mobile visualization and not applied on any of the apps, this is also not planned.
In the latest version of the Touch App we have included a separate css section in the app itself where you can add custom CSS that will be applied on this app only.
You can find it in Touch Config -> Hamburger menu on the right -> Styles -> Custom CSS section.
vicbac
Ensign vicbac
Ensign
Posted: ‎2021-01-02 04:48 AM
2300
Thanks for quick answer!
Yes I´m aware of that section aswell, but is it possible to animate one icon if a value of this object >0 in Touch config app?
Like in the PC visu we can make additional classes to make this happen.
Erwin-vd-Zwart
Janeway
Posted: ‎2021-01-02 05:33 AM
2296
It's not possible to add a custom class in Touch so that makes it hard to add a unique 'handle' to grab the desired element from the DOM, it should be possible to grab the element on the attributes like the address where it's attached to or the name in the control element but to be honest that will give you some chalenges (: So the simple answer is no you can't do this (easily).
vicbac
Ensign vicbac
Ensign
Posted: ‎2021-01-02 05:49 AM
1
2293
Hehe thanks for that perfectly explained answer 🙂
So the easiest way here is to get a set of animated svg icons that I want to illustriate moving parts for.
Erwin-vd-Zwart
Janeway
Posted: ‎2021-01-02 01:21 PM
Yep (:
