Importing LUA scripts to SL
SpaceLogic KNX Forum
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • Importing LUA scripts to SL
Thomas_Rohde
Sisko Thomas_Rohde Sisko
132
Erwin-vd-Zwart
60
Heribert_Dölger
31
SpaceLogic KNX - 4ʺ Touch Unit
KNX Push Button Dynamic Labeling, universal
Wiser for KNX : logic controller
Back to SpaceLogic KNX Forum
Jakob_Pedersen
Commander Jakob_Pedersen Commander
Commander
Posted: ‎2017-03-23 09:52 AM . Last Modified: ‎2024-07-14 11:53 PM
2
735
Hello
Where is the "Import script(s)" function in the SL? From what I can tell, it's only possible to import a backup file (in a certain format) containing scripts. But that rules out the possibility of engineering LUA scripts outside of a spaceLYnk!
To clarify, we already have the script templates tested and ready, what group-addresses each individual script shall be connected to and a fairly quick way to generate all of these LUA script files (VBA application in Excel, search and replace).
We have to use 2 types of LUA script for the rooms we control, spread out across multiple SL's (148), totaling some 1500 scripts. Please don't tell me the only option is to manually engineer all of these scripts, by hand, in each and every one of our SL's!
Creating these scripts manually in each SL -
Tremendous amount of engineering time wasted due to the lack of a very basic function.
Creating these scripts in a somewhat automatic fashion outside a SL and then importing to SL -
Saving a tremendous amount of engineering time!
CC: Thomas Rohde​
PS. Tested on SL with FW 1.2.1.
PPS. Yes I am aware of page 83/chapter 4.12.8 "General scripting description" in the SL manual, listing the available actions for each script, including "Duplicate".
  • Thumbnail of SpaceLogic KNX - 4ʺ Touch Unit
  • Thumbnail of KNX Push Button Dynamic Labeling, universal
  • Thumbnail of Wiser for KNX : logic controller
View products (3)
Tags (3)
  • lua_script
  • simplify
  • spacelynk
David_Navratil
Lt. Commander David_Navratil Lt. Commander
Lt. Commander
Posted: ‎2017-03-26 11:54 PM
664
Hello Jakob,
Can you send me example of script template? Maybe you can use dynamic group object selection, but I need to see you scripts first.
Thank you.
David
Jakob_Pedersen
Commander
Posted: ‎2017-03-27 06:19 AM
Hello David
Example:
--Læser signal fra betjeningspanel og videresender det til pir
Manuel_On_Off_Tryk = event.getvalue()                --Henter værdi fra den gruppeadresse, der aktiverede script
if Manuel_On_Off_Tryk == true then                    --Kontrollerer om der er trykket Manuel On
  grp.write('1/0/16', 75)                                        --Sender værdi til pir, hvilket samtidig får den til at gå i manuel
elseif Manuel_On_Off_Tryk == false then            --Kontrollerer om der er trykket Manuel Off
  grp.write('1/0/16', 0)                                        --Sender værdi til pir, hvilket samtidig får den til at gå i manuel
end
Not sure what dynamic group object selection is?
PS. We could really need a "insert code function" for this community.
