Is there a possibility to export the 1 minute data used for the trending. You can export a .CSV but this this is only the "hour" data.
Kind regards
Trend data are stored in rrd file. It containes minute data for 1 last hour only.
I have only tried to copy this rrd file and then convert it to xls. I can see this data there.
We do not have script for direct export of minute data to csv for now.
Be aware that the reading is done once per minute only. So if the value alternates, the minute data may give not exact view of the variable.
Hour data is done by average of these 1 minute data.
Best Regards
Tomas
It can be usefull this script to save to txt file on ftp..
file paket 1 month..
This is what I use..
If you put in a resident script 1 minute ..
-- this script generates 1 file per month called.. /home/ftp/registros/2015-04-registros.txt
os.execute('mkdir -p /lib/genohm-scada/mnt/iNt')
os.execute('mkdir -p /home/ftp/registros')
os.execute('mkdir -p /lib/genohm-scada/mnt/iNt/registros')
mnt=io.readproc('df -h 2>/dev/null'):match('/home/ftp')
if mnt then
else
os.execute('mount /lib/genohm-scada/mnt/iNt /home/ftp')
end
Ph=(grp.getvalue('0/4/24'))
hT=(grp.getvalue('1/0/5'))
taext=(grp.getvalue('0/4/0'))
fitxer=string.format('/home/ftp/registros/%s-%s-registros.txt',os.date('%Y'),os.date('%m'))
dato = string.format('Fecha, %s, kWh Termo=, %s, horas Termo=, %s,Ta Exterior=, %s,Humedad=,%s',os.date('%c'),Ph,hT,taext,humedad )
log ('Nom fitxer:' .. fitxer .. ' Datos:' .. dato )
file=io.open(fitxer, 'a+')
file:write(dato .. '\r\n')
file:close()
--log..
--string: Nom fitxer:/home/ftp/registros/2015-04-registros.txt Datos:Fecha, Fri Apr 10 13:21:56 2015, kWh Termo=, 3.84, horas Termo=, 481.92,Ta Exterior=, 24.2,Humedad=,nil
just FYI ..
ftp://ftp:password@192.168.3.69/registros/
Index of /registros/
Name Size Date Modified
[parent directory]
2014-09-registros.txt 213 kB 9/30/14, 12:00:00 AM
2014-10-registros.txt 222 kB 10/10/14, 12:00:00 AM
2015-04-registros.txt 1.6 kB 4/10/15, 11:31:00 AM
Fecha, Fri Apr 10 13:17:49 2015, kWh Termo=, true, horas Termo=, false,Ta Exterior=, nil,Humedad=,nil
Fecha, Fri Apr 10 13:18:50 2015, kWh Termo=, true, horas Termo=, false,Ta Exterior=, nil,Humedad=,nil
Fecha, Fri Apr 10 13:19:10 2015, kWh Termo=, true, horas Termo=, false,Ta Exterior=, nil,Humedad=,nil
Fecha, Fri Apr 10 13:20:10 2015, kWh Termo=, true, horas Termo=, false,Ta Exterior=, nil,Humedad=,nil
Fecha, Fri Apr 10 13:21:10 2015, kWh Termo=, true, horas Termo=, false,Ta Exterior=, nil,Humedad=,nil
Fecha, Fri Apr 10 13:22:56 2015, kWh Termo=, 3.84, horas Termo=, 481.92,Ta Exterior=, 24.2,Humedad=,nil
Fecha, Fri Apr 10 13:23:57 2015, kWh Termo=, 3.84, horas Termo=, 485.12,Ta Exterior=, 24.2,Humedad=,nil
Fecha, Fri Apr 10 13:24:57 2015, kWh Termo=, 3.84, horas Termo=, 485.12,Ta Exterior=, 24.2,Humedad=,nil
Fecha, Fri Apr 10 13:25:57 2015, kWh Termo=, 3.84, horas Termo=, 485.12,Ta Exterior=, 24.2,Humedad=,nil
Fecha, Fri Apr 10 13:26:57 2015, kWh Termo=, 3.84, horas Termo=, 485.12,Ta Exterior=, 24.2,Humedad=,nil
Fecha, Fri Apr 10 13:27:57 2015, kWh Termo=, 3.84, horas Termo=, 485.12,Ta Exterior=, 24.2,Humedad=,nil
Fecha, Fri Apr 10 13:28:57 2015, kWh Termo=, 3.84, horas Termo=, 479.04,Ta Exterior=, 24.2,Humedad=,nil
Fecha, Fri Apr 10 13:29:57 2015, kWh Termo=, 3.84, horas Termo=, 479.04,Ta Exterior=, 24.3,Humedad=,nil
Fecha, Fri Apr 10 13:30:58 2015, kWh Termo=, 3.84, horas Termo=, 479.04,Ta Exterior=, 24.3,Humedad=,nil
Fecha, Fri Apr 10 13:31:58 2015, kWh Termo=, 3.84, horas Termo=, 479.04,Ta Exterior=, 24.3,Humedad=,nil
Fecha, Fri Apr 10 13:32:58 2015, kWh Termo=, 3.84, horas Termo=, 479.04,Ta Exterior=, 24.3,Humedad=,nil
Hello Esteve,
Thanks for the script, I will test this.
Kind regrads
