Trend log for a long time
SpaceLogic KNX Forum
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • Trend log for a long time
Thomas_Rohde
Sisko Thomas_Rohde Sisko
132
Erwin-vd-Zwart
60
Heribert_Dölger
31
SpaceLogic KNX - 4ʺ Touch Unit
KNX Push Button Dynamic Labeling, universal
Wiser for KNX : logic controller
Back to SpaceLogic KNX Forum
Gustavo_Chiarelli
Lieutenant JG Gustavo_Chiarelli Lieutenant JG
Lieutenant JG
Posted: ‎2015-04-15 12:19 PM . Last Modified: ‎2024-07-15 12:00 AM
654
Hi everyone,
We have a nice case here in Brazil, it is about a Bayer building 100% efficiency with green building platinum brand.
This building was a partnership between Bayer and Schneider to use KNX automation, and in past(3 year ago) we needed a supervisory software, but the only software that we have to use with KNX was Schneider Vijeo Citect. In other words, a NASA space ship to cross the street.
Well today, the costumer hates vijeo citect, because vijeo is to industrial application and not friendly to BMS applications, but your principally concern is trend log data, because they need prove that they building is a zero electric consumption building in the end of years ( energy generated - energy consumption = 0) and every year they need prove the best practicals made in the building to improve the efficiency.
We donate a homelink to Bayer, because this partnership brougth some business to us, but I don't know if it will be enough.
Bayer wants migrate Vijeo Citect log data (in CSV or SQL) to homelynk(to turn off the Vijeo Citect).
And they want to that the homelynk make a backup of trend log history in a file server located in Bayer's network.
My doubt is, Is it possible?
Some script, tricks or some else to solve this......
Because commercial and technical issues in this project, we can't donate a Enterprise Server or Automation Server (SBO offer).
Thanks for your help!
  • Thumbnail of SpaceLogic KNX - 4ʺ Touch Unit
  • Thumbnail of KNX Push Button Dynamic Labeling, universal
  • Thumbnail of Wiser for KNX : logic controller
View products (3)
sesa299442
sesa299442 Schneider Alumni (Retired)
Posted: ‎2015-04-16 12:38 AM
Gustavo,
homeLYnk can store maximum 10 000 object logs. Logs are cyclically overwritten.
We are able to set export to FTP or via email with attachment in CSV format. This can be done via LUA scripts.
As the storage capacity of object logs is not to big, it does not make sense to import data homeLYnk, I think.
I was about to suggest you to use SBO for your purposes.
It is possible to export data from homeLYnk to SBO over BACnet.
sesa299442
Gustavo,
