Hello
I couldn't find the ETS File for the weather station (MTN682991) in ETS5 catalog or in SE KNX Website!
Hello IC-Systems,
when you install the PlugIn the ETS-Application will be installed in a seperate folder also.
During the installation-process of the PlugIn you will get a notification where the dedicated folder is placed.
You need to install the plugin by the installer in the attachment, during installation you can provide the path to the .vdx file (default something like "C:\Program Files (x86)\Ets3PlugIn\.." and that .vdx needs to be imported into the ETS
Hello IC-Systems,
@Erwin-vd-Zwart @Thomas_Rohde did you try to install this software on Schneider computer? can you share this .vdx file? I get error: Die Datei konnte nicht im temporaren ordner ausgefuhrt werden. Setup abgebrochen Fehler 740 the requested operation requires elevation
Is it supported under Windows 10?
Yes i can run it under windows 10, could it be you have restrictions by the IT department in installing applications?
1) Yes, I have some additional security software but it is aware of this program, and it looks like it allows for program execution :
2) @Erwin-vd-Zwart would it be possible that you will attach .vdx (example) file?
