SpaceLynk Modbus RTU devices
SpaceLogic KNX Forum
Select a Country
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • SpaceLynk Modbus RTU devices
Thomas_Rohde
Thomas_Rohde Champion
141
Erwin-vd-Zwart
Erwin-vd-Zwart Champion
63
Heribert_Dölger
Heribert_Dölger Leader
34
SpaceLogic KNX - 4ʺ Touch Unit
KNX Push Button Dynamic Labeling, universal
Wiser for KNX : logic controller
Back to SpaceLogic KNX Forum
Horacio1
Horacio1 Explorer
Explorer
Posted: ‎2023-02-01 09:49 AM . Last Modified: ‎2024-07-14 11:43 PM
1861
Hello everybody,
Can somebody tell if you have connected more than 31 modbus rtu devices to the spacelynk, using a repeater?
I don´t find anything related to that subject, the User Guide just mention (I leave the capture in the attachments), the maximum number of devices, but does mention without repeater.
Thanks for the suport
  • Thumbnail of SpaceLogic KNX - 4ʺ Touch Unit
  • Thumbnail of KNX Push Button Dynamic Labeling, universal
  • Thumbnail of Wiser for KNX : logic controller
View products (3)
  • SpaceLYnk
Coppo
Coppo Mentor
Mentor
Posted: ‎2023-02-02 03:40 PM . Last Modified: ‎2023-02-02 03:41 PM
most SE documents list 31 devices as a theoretical maximum.
the realitiy is you would have to ramp down polling to support it and it may still have reliability problems .
also some SE devices use more than 1 modbus address
(like ACB switches that can require 2 or 3 modbus addresses ).
domotiqa
domotiqa
Mentor
Posted: ‎2023-02-02 12:03 AM
always better to use EGX150 when lots of modbus device in other area. So much problem otherwise.
Smarthome & Smartbuilding Expert
David_Navratil
David_Navratil Mentor
Mentor
Posted: ‎2023-02-02 12:30 AM
Hello Horacio,
It is maybe wrong formatting. Without repeater, you can have max 31 Modbus devices.
With repeater you can extend this number. Always keep in mind that when you will pooling fast the data from Modbus devices CPU load can rapidly increase and cause malfunction of whole system.
Kind regards
David
Coppo
Coppo Mentor
Mentor
