Dali Gateway
SpaceLogic KNX Forum
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • Dali Gateway
Thomas_Rohde
Sisko Thomas_Rohde Sisko
132
Erwin-vd-Zwart
60
Heribert_Dölger
31
SpaceLogic KNX - 4ʺ Touch Unit
KNX Push Button Dynamic Labeling, universal
Wiser for KNX : logic controller
Back to SpaceLogic KNX Forum
Posted: ‎2020-01-06 03:48 AM . Last Modified: ‎2024-07-14 11:49 PM
6
1327
Dali Gateway
Hello all of you,
I have a question about dali gateway the thing is sometimes error led is opening but I don't see any problem to Dali working Why this led is opening When there is no error?
Thank you for helping from now
Best regards
  • Thumbnail of SpaceLogic KNX - 4ʺ Touch Unit
  • Thumbnail of KNX Push Button Dynamic Labeling, universal
  • Thumbnail of Wiser for KNX : logic controller
View products (3)
  • Wiser for KNX
Tags (2)
  • dali
  • knx
Thomas_Rohde
Sisko
Posted: ‎2020-01-06 06:17 AM
1323
by reading your topic I am not pretty sure that I got your topic 100% correctly.
" ... is sometimes error led is opening ..." => is it really only sometimes On or permanently On?
When it is really only sometimes On that please try to identify what happens when it goes ON and
what happens when it goes OFF. In this case I would guess that there is something strange within the installation.
In case it is permanently switched on I can gave an example of my workbench. My Error-LED is as well permanently
switched on due to the fact that one ECG has three outputs but just two them are used/connected/wired.
Please let me know.
Kind regards
Thomas
Kind regards
Thomas
Application Design Engineer
Replies 6
Omaelk
Janeway Omaelk
Janeway
Posted: ‎2020-01-06 05:57 AM
Hey @Anonymous user, thank you for your question
I moved your question to the KNX forum when the community of experts will be able to provide you the right support and answer your question!
PS: don't hesitate to check the Knowledge base and use the search bar with keywords. there is a lot of content discussed everyday and your issue may have already been solved 😉
Thomas_Rohde
Sisko
1324
Please let me know.
Kind regards
Thomas
Kind regards
Thomas
Posted: ‎2020-01-06 06:39 AM
1321
Hello @Thomas_Rohde ,
Firstly thank you for your answer,
I made project consist of Dali. First times error led did not light. After a while error led started to light and never again off but system is working correctly. In the Project there are ECG's two outputs but one of them are connected. I mean it's depending on ECG connections. Am I right ?
Kind regards
Fethi
Thomas_Rohde
Sisko
Posted: ‎2020-01-06 11:08 PM
1318
Hello Fethi,
to "I mean it's depending on ECG connections. Am I right ?"
YES, this can be the rootcause. Maybe you have the chance to connect a second light in a small sample system for validation.
Kind regards
Thomas
Kind regards
Thomas
Thomas_Rohde
Sisko
Posted: ‎2020-01-12 11:00 PM
1314
Hello Fethi,
any news on this topic?
Kind regards
Thomas
Posted: ‎2020-01-13 12:18 AM
Hello Thomas,
You are right on this topic. When I connect the ballast which has two output but I connected only one output. Dali's Error LED goes ON. But I use ballast which have only one output. LED didn't on. Thank you for helping again.
Best Wishes
Fethi
