DCA problem for MTN6725-0004 and MTN6725-0003 Windows 11 ETS6
SpaceLogic KNX Forum
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • DCA problem for MTN6725-0004 and MTN6725-0003 Windows 11 ETS6
Thomas_Rohde
Sisko Thomas_Rohde Sisko
132
Erwin-vd-Zwart
60
Heribert_Dölger
31
SpaceLogic KNX - 4ʺ Touch Unit
KNX Push Button Dynamic Labeling, universal
Wiser for KNX : logic controller
Back to SpaceLogic KNX Forum
PiotrJakubczyk
Sisko PiotrJakubczyk Sisko
Sisko
Posted: ‎2023-04-18 01:07 AM . Last Modified: ‎2024-07-14 11:42 PM
1470
Hello
Hello I'm unable to assign ECG to group under DCA app. During post installation, window is not visible.  
Windows 11
ETS6
DCA7313
firmware 0.3.5
On windows taskbar I see that window is present somewhere but unable to find it.
Normally it should be visible like this
  • Thumbnail of SpaceLogic KNX - 4ʺ Touch Unit
  • Thumbnail of KNX Push Button Dynamic Labeling, universal
  • Thumbnail of Wiser for KNX : logic controller
View products (3)
  • Local App
Erwin-vd-Zwart
Janeway
Posted: ‎2023-04-18 01:21 AM
I have seen this issue before, also in other Windows versions and it's probaly related when using external display, the application opens outside your default windows screen, you should be able to right click on the application in the taskbar and select "move" and then use the arrow key to move it in your default window.
As far as i know this is not something in the application but something MS Windows related
See: https://www.technipages.com/bring-off-screen-window-back-onto-screen/
Erwin-vd-Zwart
Janeway
esteve_budia
Lieutenant esteve_budia Lieutenant
Lieutenant
Posted: ‎2023-07-13 11:12 PM
I've seen other times in other windows versions, you can display it with right-click here:
And then "Maximize".
After this, you'll have an option to use DCA and dont display more.
