Curtains
SpaceLogic KNX Forum
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • Curtains
Thomas_Rohde
Sisko Thomas_Rohde Sisko
132
Erwin-vd-Zwart
60
Heribert_Dölger
31
SpaceLogic KNX - 4ʺ Touch Unit
KNX Push Button Dynamic Labeling, universal
Wiser for KNX : logic controller
Back to SpaceLogic KNX Forum
Posted: ‎2021-08-20 02:47 AM . Last Modified: ‎2024-07-14 11:46 PM
843
Curtains
Can someone support for me in programming curtains with relays and multitouch
  • Thumbnail of SpaceLogic KNX - 4ʺ Touch Unit
  • Thumbnail of KNX Push Button Dynamic Labeling, universal
  • Thumbnail of Wiser for KNX : logic controller
View products (3)
  • SpaceLYnk
Thomas_Rohde
Sisko
Posted: ‎2021-08-30 11:26 PM
Hello Suketh,
I am still not sure that I get your question in the right way.
When you want to control this curtain only you need to link one group-address to each of the yellow marked objects.
On the actuator side it is the same. Below you will see the parameter and objects from the SpaceLogic Switch Blind Actuator.
Objects to link with group addressesObjects to link with group addresses
Kind regards
Thomas
Application Design Engineer
Replies 6
Posted: ‎2021-08-20 02:49 AM
842
Which is the better option to select in relays blind or roller shutter?
In multi touch which screen options I should use
Thomas_Rohde
Sisko
Posted: ‎2021-08-23 11:27 PM
838
Hello Suketh,
when it is just a normal curtain which you can move (left+right+stop) then roller shutter is the correct selection.
Kind regards
Thomas
Posted: ‎2021-08-26 10:26 PM
832
Thanks for the reply
in relays if i use roller shutter option it gives, movement object, stop object, height and feedback object for moving and last direction, how many group address should i create
also in multi touch pro, which option i should use (blind, roller shutter)
please elaborate
Thomas_Rohde
Sisko
Posted: ‎2021-08-27 04:56 AM
827
Hi Suketh,
within the Multitouch you have two options for the rollershutter:
- Vertical design
- Circle design
I would select the circle one because the vertical is maybe not that intuitive for a curtain but feel free to take your own choice or customer wish.
For both you see attached the dedicated pictures.
Vertical design - ParameterVertical design - ParameterVertical design - Group-ObjectsVertical design - Group-ObjectsSlider design - ParameterSlider design - ParameterSlider design - Group-ObjectsSlider design - Group-Objects
Kind regards
Thomas
Posted: ‎2021-08-30 09:55 PM
823
this part i have clarity
i want details on relays end..
since how many group address we have to create
Thomas_Rohde
Sisko
Hello Suketh,
Kind regards
Thomas
