Connect to UPS Via SNMP
SpaceLogic KNX Forum
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • Connect to UPS Via SNMP
Thomas_Rohde
Sisko Thomas_Rohde Sisko
132
Erwin-vd-Zwart
60
Heribert_Dölger
31
SpaceLogic KNX - 4ʺ Touch Unit
KNX Push Button Dynamic Labeling, universal
Wiser for KNX : logic controller
Back to SpaceLogic KNX Forum
IC_Systems
Captain IC_Systems
Captain
Posted: ‎2022-09-13 12:17 AM . Last Modified: ‎2024-07-14 11:43 PM
732
Hello
I have a UPS support SNMP and I need to connect with SL.
Could you share an example?
Best Regards,
  • Thumbnail of SpaceLogic KNX - 4ʺ Touch Unit
  • Thumbnail of KNX Push Button Dynamic Labeling, universal
  • Thumbnail of Wiser for KNX : logic controller
View products (3)
  • SpaceLYnk
Erwin-vd-Zwart
Janeway
Posted: ‎2022-09-13 01:39 AM
2
730
This is officially not supported, however it can be done if you have the libnetsnmp and luasnmp packages installed
Run as resident at 0 sec:
os.sleep(1)
if not devices then
  require('snmp')
  devices = {
      ip = '192.168.1.1',
      port = 161,
      mapping = {
        { oid = '1.3.6.1.4.1.14988.1.1.3.8.0', addr = '32/0/0' },
        { oid = '1.3.6.1.4.1.14988.1.1.3.10.0', addr = '32/0/1' },
      ip = '192.168.1.2',
      mapping = {
        { oid = '1.3.6.1.4.1.14988.1.1.3.8.0', addr = '32/0/3' },
        { oid = '1.3.6.1.4.1.14988.1.1.3.10.0', addr = '32/0/4' },
      ip = '192.168.1.3',
      mapping = {
        { oid = '1.3.6.1.4.1.14988.1.1.3.8.0', addr = '32/0/5' },
        { oid = '1.3.6.1.4.1.14988.1.1.3.10.0', addr = '32/0/6' },
      ip = '192.168.1.4',
      mapping = {
        { oid = '1.3.6.1.4.1.14988.1.1.3.8.0', addr = '32/0/7' },
        { oid = '1.3.6.1.4.1.14988.1.1.3.10.0', addr = '32/0/8' },
end
for _, dev in ipairs(devices) do
  local conn, err = snmp.open({
    version = snmp.SNMPv1,
    community = 'public',
    port = dev.port or 161,
    peer = dev.ip,
  if conn then
    for _, map in ipairs(dev.mapping) do
      local res, err = conn:get(map.oid)
      if res and res.value ~= nil then
        grp.checkwrite(map.addr, res.value)
      else
        alert('SNMP read from %s %s failed (%s)', dev.ip, map.oid, tostring(err))
      end
    end
  else
    alert('SNMP connection to %s failed (%s)', dev.ip, tostring(err))
  end
end
Erwin-vd-Zwart
Janeway
2
731
os.sleep(1)
if not devices then
  require('snmp')
  devices = {
      ip = '192.168.1.1',
      port = 161,
      mapping = {
      ip = '192.168.1.2',
      mapping = {
      ip = '192.168.1.3',
      mapping = {
      ip = '192.168.1.4',
      mapping = {
end
    peer = dev.ip,
  if conn then
      else
      end
    end
  else
  end
end
IC_Systems
Captain IC_Systems
Captain
Posted: ‎2022-09-15 03:23 AM
726
Thanks @Erwin-vd-Zwart
Do you plan to support it officially?
If I want to change the version, I just should change it from here:
Best Regards,
Erwin-vd-Zwart
Janeway
Posted: ‎2022-09-15 03:31 AM
No we will not support it officially, the typical market for this kind of solutions is BMS, and the we have an official supported SmartConnector for SNMP traps, so that is our  preferred solution.
