BACnet integration guide
SpaceLogic KNX Forum
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • BACnet integration guide
Thomas_Rohde
Sisko Thomas_Rohde Sisko
132
Erwin-vd-Zwart
60
Heribert_Dölger
31
SpaceLogic KNX - 4ʺ Touch Unit
KNX Push Button Dynamic Labeling, universal
Wiser for KNX : logic controller
Back to SpaceLogic KNX Forum
PiotrJakubczyk
Sisko PiotrJakubczyk Sisko
Sisko
Posted: ‎2022-09-02 06:45 AM . Last Modified: ‎2024-07-14 11:44 PM
1031
Hello
According to AN001_spaceLYnk_integration_using_BACnet_v2.0.pdf there info that "spaceLYnk can distribute up to 500 Objects to BACnet". Is it newest version of document available on global site? https://www.se.com/ww/en/download/document/AN001_SL/
I wonder if this is still actual because referenced version of spaceLYnk is 1.0 and Buidling Operation WorkStaton 1.4. Enterprise Server Lastest Version. Also in this forum I have found that spaceLYnk is suporting 256 BACnet COV. In fact i have found in spaceLYnk user guide photo with number 256 on page 140. https://download.schneider-electric.com/files?p_enDocType=User+guide&p_File_Name=SpaceLYnk+%28LSS100...
500 is reasonable value for me (at least from embedded device point of view) but I'm  pushed to check this because other person is stating values like 2000 BACnet objects per device... I suspect that all versions are true but with reasonable response time more real value is like 500.
  • Thumbnail of SpaceLogic KNX - 4ʺ Touch Unit
  • Thumbnail of KNX Push Button Dynamic Labeling, universal
  • Thumbnail of Wiser for KNX : logic controller
View products (3)
  • Protocols
  • SpaceLYnk
Thomas_Rohde
Sisko
Posted: ‎2022-09-05 12:08 AM
Hi Piotr,
the AN001 is not updated since a while so it not represents the actual data.
I recommend, as you already stated in your post, to check the userguide.
This is up to date and in the section "4.8 Differences between spaceLYnk and Wiser
for KNX" you will find the actual data.
Kind regards
Thomas
Application Design Engineer
Thomas_Rohde
Sisko
Hi Piotr,
Kind regards
Thomas
PetrMares
Commander PetrMares Commander
Commander
Posted: ‎2022-09-05 12:54 AM
yes. the Application note is a bit outdated. What you can read in AN is valid for HW1.xx. The latest HW3.xx can handle indeed 2000 objects exported to BACnet with maximum 4096 COV subscriptions.
