SpaceLogic KNX Touch IP 7 inch HMI product announcement
SpaceLogic KNX Forum
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • SpaceLogic KNX Touch IP 7 inch HMI product announcement
Thomas_Rohde
Sisko Thomas_Rohde Sisko
132
Erwin-vd-Zwart
60
Heribert_Dölger
31
SpaceLogic KNX - 4ʺ Touch Unit
KNX Push Button Dynamic Labeling, universal
Wiser for KNX : logic controller
Back to SpaceLogic KNX Forum
PiotrJakubczyk
Sisko PiotrJakubczyk Sisko
Sisko
Posted: ‎2022-09-16 06:34 AM . Last Modified: ‎2024-07-14 11:43 PM
6
1439
I will share it here:
Hello KNX Community,
I am happy to share the product announcement of the new SpaceLogic KNX Touch IP 7 inch.
main highlights:
• 7“touch display
• Intuitive thanks to the Wiser for KNX visualization
• Easy set up and configuration
• Horizontal and vertical installation
• WiFi connectivity, 24V power supply
• Available in black and white
The product will be available on se.com in 48 hours.
  • Thumbnail of SpaceLogic KNX - 4ʺ Touch Unit
  • Thumbnail of KNX Push Button Dynamic Labeling, universal
  • Thumbnail of Wiser for KNX : logic controller
View products (3)
  • Information
Replies 6
laurence_crowhu
Ensign laurence_crowhu
Ensign
Posted: ‎2022-09-17 11:01 PM . Last Modified: ‎2022-09-17 11:03 PM
1433
It says available - global. Does this mean it is available in Australia, will it work with cbus SpaceLogic ac2. Have you got more technical info, eg install and config documentation ?
PiotrJakubczyk
Sisko
Posted: ‎2022-09-19 02:45 AM . Last Modified: ‎2022-09-19 03:24 AM
1410
It says available - global. Does this mean it is available in Australia - it depends from Schneider Electric Australia organization - I would contact them and ask how long it will take to introduce product to local market (..and if they decide to introduce product to market. It is not that simple to decide because mentrioned cbus SpaceLogic ac2 wasn't mentioned so it must be tested by someone). It would be helpful if you share attached product announcement to them. Mentioned time (24 hours) is for sure not time when product will be available in your country.
Currently I can't find product on global webpage (only local Germany webpage https://www.se.com/de/de/product/MTN6260-7770/spacelogic-knx-touch-ip-7-zoll-smart-screen-wei%C3%9F/
Here is user guide:
https://download.schneider-electric.com/files?p_enDocType=User+guide&p_File_Name=MTN6260-77xx_KNX_DU...
Instalation manual:
https://download.schneider-electric.com/files?p_Doc_Ref=MTN6260-77xx_HW&p_enDocType=Instruction+shee...
(There is only mentioned Wiser for KNX and SpaceLYnk so it wasn't tested with cbus SpaceLogic ac2)
laurence_crowhu
Ensign
Posted: ‎2022-09-19 03:45 AM
1404
As I thought global doesn’t mean global 😞
PetrMares
Commander PetrMares Commander
Commander
Posted: ‎2022-09-19 03:51 AM
1401
the touch panel has been made exclusively for Wiser for KNX, spaceLYnk controllers. Cbus NAC, SHAC are very similar at least on visualization side. The idea is to use it primarily for Touch visualization, but still possible to use PC/Tablet visualization which is also in the NAC, SHAC.
In theory it should even work now, just not tested. Touch panel does not care if running KNX or Cbus.
Nevertheless, a Cbus was not in scope of the project.
laurence_crowhu
Ensign
Posted: ‎2022-09-19 03:53 AM
1399
How do I get one i Australia to test with wiser ac?
PetrMares
Commander
Posted: ‎2022-09-19 04:26 AM
I would say you should contact offer manager of NAC, SHAC. it is not only about the technical feasibility, but first look at business side.
