Conditional with text string variable
SpaceLogic KNX Forum
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • Conditional with text string variable
Thomas_Rohde
Sisko Thomas_Rohde Sisko
132
Erwin-vd-Zwart
60
Heribert_Dölger
31
SpaceLogic KNX - 4ʺ Touch Unit
KNX Push Button Dynamic Labeling, universal
Wiser for KNX : logic controller
Back to SpaceLogic KNX Forum
jorge_marti
jorge_marti Schneider Alumni (Retired)
Posted: ‎2014-11-03 07:05 AM . Last Modified: ‎2024-07-15 12:04 AM
3
861
Hi colleagues,
I want to configure schedulers linked to the RTC modes in a "User friendly" way.
In the scheduler, tje value to set different Comfort, Night or standby modes are numbers, for End User that is not comprehensive.
What I planed:
- Schedulers with 14 bytes variables and string value with the values: COMFORT, NIGHT or STANDBY
- To convert these strings to the corresponding value (1,2,3) I plan an script... but then my question appears:
     How can I use a conditional and string?
Tried:
if (value == 'COMFORT') then
end
But when saving, system rejects it. I tried with "COMFORT" also.
How can this be done?
Do you have any other idea how to do the same in a User Friendly way?
Thanks a lot
  • Thumbnail of SpaceLogic KNX - 4ʺ Touch Unit
  • Thumbnail of KNX Push Button Dynamic Labeling, universal
  • Thumbnail of Wiser for KNX : logic controller
View products (3)
lfiat
lfiat Schneider Alumni (Retired)
Posted: ‎2014-11-05 01:47 AM
Hi Jorge,
I tested quickly this script:
value = 'COMFORT'
  log("Test1: OK value = COMFORT")
else
  log("Test1: NOK value != COMFORT: value =",value)
end
value = 'NIGHT'
  log("Test2: OK value = COMFORT")
else
  log("Test2: NOK value != COMFORT: value =",value)
end
=> it works: see screenshot of log page.
So I don't understand your issue?
Regards
Lionel
vaca
vaca Schneider Alumni (Retired)
Posted: ‎2014-11-05 02:27 AM
or you can do it via Lua table with simple mapping:
local mapping = { COMFORT = 1, NIGHT = 2, STANDBY = 3 }
realValue = mapping[value]
or more general mapping if you need to do some code with mapping
local mapping = {
    COMFORT = function()
        -- some coding like 'local a = 5; return 1'
    end,
    NIGHT = function()
        -- some coding like 'grp.update("1/1/20", 18); return 2'
    end,
    STANDBY = function()
        -- some coding like 'log("hurray, it's working"); return 3'
    end,
realValue = mapping[value]()
jorge_marti
Posted: ‎2014-11-11 10:37 AM
Thanks colleagues for helpful answers.
Finally I did it with "Custom Values". I'm learning by doing!
