Enabling scheduler from Script/Group address in HL
SpaceLogic KNX Forum
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • Enabling scheduler from Script/Group address in HL
Thomas_Rohde
Sisko Thomas_Rohde Sisko
132
Erwin-vd-Zwart
60
Heribert_Dölger
31
SpaceLogic KNX - 4ʺ Touch Unit
KNX Push Button Dynamic Labeling, universal
Wiser for KNX : logic controller
Back to SpaceLogic KNX Forum
jorge_marti
jorge_marti Schneider Alumni (Retired)
Posted: ‎2014-11-11 10:46 AM . Last Modified: ‎2024-07-15 12:04 AM
6
963
Dear all,
Here I am again with question. I tried to reach the answer in documentation but no success.
The use case is the following. A house with quite fixed schedules for Heating. But when leaving out complete day Schedulers should have no effect and Standby mode should be selected until user is back.
There are several ways to do it and I have one way already done and working but.... The cleaner one for me would be to disable schedulers with a KNX telegram at the door push button. Is it possible that way?
Thanks for answers!
  • Thumbnail of SpaceLogic KNX - 4ʺ Touch Unit
  • Thumbnail of KNX Push Button Dynamic Labeling, universal
  • Thumbnail of Wiser for KNX : logic controller
View products (3)
Replies 6
esteve_budia
Lieutenant esteve_budia Lieutenant
Lieutenant
Posted: ‎2014-11-11 11:52 PM
As same as you can enable/disable a script..
script.enable('My own script')
script.disable('My own script')
It would be nice ...
scheduler.enable('My scheduler')
Erwin-vd-Zwart
Janeway
Posted: ‎2014-11-12 03:55 AM
4
897
Hi Jorge,
You can disable and enable the scheduler with a little script by read/write directly to the DB.
Try this:
-- Function Enable Schedular (can be added to common functions and removed from this script)
function scheduler_enable(scheduler_name)
  query = 'SELECT id, name, active FROM schedulers'
  for _, scheduler in ipairs(db:getall(query)) do
  if scheduler.name == scheduler_name then
    db:update('schedulers', { active = 1 }, { id = scheduler.id })
  end
  end
end
-- Function Disable Schedular (can be added to common functions and removed from this script)
function scheduler_disable(scheduler_name)
    db:update('schedulers', { active = 0 }, { id = scheduler.id })
  end
  end
end
-- Action to change scheduler (event based)
eventvalue = event.getvalue()
if eventvalue == true then
  scheduler_enable('My scheduler')
else
  scheduler_disable('My scheduler')
end
Best regards,
Erwin
jorge_marti
Posted: ‎2014-11-13 12:48 AM
897
Hi
It works perfectly. I would ask colleagues to add it as common function (same as sunset/sunrise).
I have a second question. As soon as schedulers are enabled, is it possible to force them to send the value that corresponds to the time is it?
Use case:
I leave home so all RTC goes to Standby and schedulers are disabled.
I arrive home at 13:00, so I activate schedulers, and because it is lunch time, kitchen is intended to be in Comfort.
If I arrive home at 20:00 then the room and living room should be in Comfort.
So the status when I come back should follow the schedulers.
Thanks a lot!
esteve_budia
Lieutenant
Posted: ‎2014-11-13 01:05 AM
897
-- sunrise / sunset / elevation / azimut calculation
function rscalc(latitude, longitude, when)
  local pi = math.pi
  local doublepi = pi * 2
  local rads = pi / 180.0
  local graus= 180.0 /pi
  local TZ = function(when)
    local ts = os.time(when)
    local utcdate, localdate = os.date('!*t', ts), os.date('*t', ts)
    localdate.isdst = false
     diff = os.time(localdate) - os.time(utcdate)
     dif=math.floor(diff/3600)
    return math.floor(diff / 3600)
  end
  local diff = os.time(localdate) - os.time(utcdate)
  local dif=math.floor(diff/3600)
  local hora = tonumber (os.date('%H'))
  local minut = tonumber (os.date('%M'))
  local minut_d= (minut/60)
  local hora_solar = hora - dif + minut_d
  local range = function(x)
    local a = x / doublepi
    local b = doublepi * (a - math.floor(a))
    return b < 0 and (doublepi + b) or b
  end
  when = when or os.date('*t')
  local y2k = { year = 2000, month = 1, day = 1 }
  local y2kdays = os.time(when) - os.time(y2k)
  y2kdays = math.ceil(y2kdays / 86400)
  local meanlongitude = range(280.461 * rads + 0.9856474 * rads * y2kdays)
  local meananomaly = range(357.528 * rads + 0.9856003 * rads * y2kdays)
  local lambda = range(meanlongitude + 1.915 * rads * math.sin(meananomaly) + rads / 50 * math.sin(2 * meananomaly))
local lambda_g = lambda *graus
  local obliq = (23.439 * rads) - (y2kdays * rads / 2500000)
obliq_g = obliq * graus
  local alpha = math.atan2(math.cos(obliq) * math.sin(lambda), math.cos(lambda))
  alpha_g = alpha * graus
  local declination = math.asin(math.sin(obliq) * math.sin(lambda))
  declination_g = declination *graus
  local LL = meanlongitude - alpha
  if meanlongitude < pi then
    LL = LL + doublepi
  end
  local dfo = pi / 216.45
  if latitude < 0 then
    dfo = -dfo
  end
  local fo = math.min(math.tan(declination + dfo) * math.tan(latitude * rads), 1)
  local ha = 12 * math.asin(fo) / pi + 6
  local timezone = TZ(when)
  local equation = 12 + timezone + 24 * (1 - LL / doublepi) - longitude / 15
  local sunrise, sunset = equation - ha, equation + ha
  if sunrise > 24 then
    sunrise = sunrise - 24
  end
  if sunset > 24 then
    sunset = sunset - 24
  end
  -- calculo de la elevacion
  local omega=(hora_solar-12)*15 --graus
  local zenit= math.acos(  ((math.cos(latitude*rads))*(math.cos(declination))*(math.cos(omega*rads))) + ((math.sin(latitude*rads))*(math.sin(declination)))  )
  local zenit_g=zenit*graus
  local elevacion=(90-zenit_g)
  -- calculo de azimut
  az=math.acos((((math.cos(latitude*rads))*(math.sin(declination)))-((math.cos(omega*rads))*(math.sin(latitude*rads))*(math.cos(declination))))/((math.cos(elevacion*rads))))
  if omega>0 then
    azimut=360-(az*graus)
  else
    azimut=az*graus
  end
   return math.floor(sunrise*60), math.ceil(sunset*60),elevacion,azimut
end
5181
jorge_marti
Posted: ‎2014-11-13 01:08 AM
897
HI Esteve,
I know sunset/sunrise is by default included.
What I wanted to say is that Scheduler-enable could be also by default included.
esteve_budia
Lieutenant
Posted: ‎2014-11-13 01:21 AM
I know. I added the azimut and sun elevation to this function 6 moths ago and working fine for testing. If officially someone wants to revise the modification and include to common functions it would be nice. This is an added value to our controller to do building blind controler position depending on sun positon.
