AN003_SL - Modbus Power meters and spaceLYnk
SpaceLogic KNX Forum
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • AN003_SL - Modbus Power meters and spaceLYnk
Thomas_Rohde
Sisko Thomas_Rohde Sisko
132
Erwin-vd-Zwart
60
Heribert_Dölger
31
SpaceLogic KNX - 4ʺ Touch Unit
KNX Push Button Dynamic Labeling, universal
Wiser for KNX : logic controller
Back to SpaceLogic KNX Forum
sesa296387
sesa296387 Schneider Alumni (Retired)
Posted: ‎2014-10-07 01:18 AM . Last Modified: ‎2024-07-15 12:05 AM
760
Reading basic and complete Modbus parameters from Acti9 Power meters via LUA scripts
  • Thumbnail of SpaceLogic KNX - 4ʺ Touch Unit
  • Thumbnail of KNX Push Button Dynamic Labeling, universal
  • Thumbnail of Wiser for KNX : logic controller
View products (3)
AN003_Modbus Power meters and spaceLYnk.zip
Tags (3)
  • application_note
  • space_automation
  • spacelynk
Replies 4
dborle
dborle Schneider Alumni (Retired)
Posted: ‎2014-11-07 06:23 AM
Hi Darya,
I've tried your scripts and they work fine.
No I've tried to modify the script for reading values of other power meters like PM800. But against what is written in your AN I can't find supported datapoint formats like Int16 and Int32, only UInt16 and UInt32. Please can you give me a hint, how I will have to modify the script to support signed integers (I can read all the values from the PM800, but negative values are showed as unsigned values e.g. -1 -> 32767)?
Daniel
vaca
vaca Schneider Alumni (Retired)
Posted: ‎2014-11-10 08:33 AM
Hi Daniel,
Darya is not available till wednesday, so here is your answer. Extend your library MbPwmRTU.TYPES definition for these types:
Int16 = {
    size = 1,
    deltaFunct = 5,
    -- function to read value from modbus registed
    read = function(mb, address, regsize, debug)
        local ret = MbPwmRTU.mbRead(mb, address, regsize or MbPwmRTU.TYPES.UInt16.size, debug)
        return bit.band(ret, 0x7fff) * ((bit.rshift(ret, 15) == 0) and 1 or -1)
    end,
Int32 = {
    size = 2,
    deltaFunct = 5,
        local v1, v2 = MbPwmRTU.mbRead(mb, address, regsize or MbPwmRTU.TYPES.UInt32.size, debug)
        return (bit.lshift(bit.band(v1, 0x7fff), 16) + v2) * ((bit.rshift(v1, 15) == 0) and 1 or -1)
    end,
dborle
Posted: ‎2014-11-11 05:49 AM
Hi Jaroslav,
Thanks a lot for your support. Unfortunately it didn't work that way, so I had to modify your script a little bit like this:
Int16 = {
        size = 1,
        deltaFunct = MbPwmTCP._numDeltaFunct,
       local ret = MbPwmTCP.mbRead(mb, address, regsize or MbPwmTCP.TYPES.UInt16.size, debug)
       return bit.band(ret, 0x7fff) + ((bit.rshift(ret, 15) == 0) and 0 or -32768)
       end,
vaca
Posted: ‎2014-11-11 06:07 AM
Yes, you are right, I see it now, really sorry for misleading you.
It happens when you are used to work mostly with scripting languages and coding and writing to forum when asleep.
