Share Your Feedback โ Help Us Improve Search on Community! Please take a few minutes to participate in our Search Feedback Survey. Your insights will help us deliver the results you need faster and more accurately. Click here to take the survey
Latest version of Google Chrome Browser (80.0.3987.106) breaks interfaces configuration window.
FF 72.0.2 is ok
As the same behavior has been identified in dev version of Google Chrome we are working fix the issue.
Please, use older version of Chrome for IP settings or different browser.
Note: as a workaround please press F12 key (2x). This re-render the page.
Update (20200408) - Google has released Chrome version 81.0.4044.92 on 7/4/2020 which fixes the problem, without the bugfix patch.
Dear all,
the topic is solved by adding this little patch-file to the dedicated controller.
It is distributed as *.lmup file attached to this post. Please, clean browser's cache after patch.
Below you will find the steps as a reminder ๐
Hi Petr,
I faced the same issue in Admin password change page after a hardware reset. I couldn't set the password in chrome, I had to go to another browser to set the password.
Mahmoud
Yes, correct. It is same dialogue window. F12 works as well in this case, but this is more annoying because customer see empty window when he grabs a fresh new product.
Other configuration windows from system page seems work. Let's see where is the root cause.
Dear all,
Youโve reached the end of your document
