AS-P cannot read spacelynk object
SpaceLogic KNX Forum
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • AS-P cannot read spacelynk object
Thomas_Rohde
Sisko Thomas_Rohde Sisko
130
Erwin-vd-Zwart
58
Heribert_Dölger
31
FZetina
Commander FZetina Commander
29
SpaceLogic KNX - 4ʺ Touch Unit
KNX Push Button Dynamic Labeling, universal
Wiser for KNX : logic controller
Back to SpaceLogic KNX Forum
mostafa_ramadan
Ensign mostafa_ramadan
Ensign
Posted: ‎2024-05-02 03:46 AM . Last Modified: ‎2024-07-14 11:39 PM
835
Automation server can discover spacelynk as attached but when drag and drop into IP network give me upload is required to host objects and cannot download objects with device.
What should i do to fix that issue, Thanks a lot.
  • Thumbnail of SpaceLogic KNX - 4ʺ Touch Unit
  • Thumbnail of KNX Push Button Dynamic Labeling, universal
  • Thumbnail of Wiser for KNX : logic controller
View products (3)
  • SpaceLogic devices
  • SpaceLYnk
Cristiano_Carli_Ballola
Lt. Commander Cristiano_Carli_Ballola Lt. Commander
Lt. Commander
Posted: ‎2024-05-02 10:05 PM
There is no issue.
SpaceLYnk is primarily a KNX device with BACnet functionality.
From the SpaceLYnk web server you have to select which KNX object you want to submit as BACnet objects and then Upload those objects once the SpaceLYnk has been detected from your AS.
Lt. Commander
There is no issue.
Erwin-vd-Zwart
Janeway
Posted: ‎2024-05-03 10:27 PM
You need to check the export flag on each object in the spaceLYnk to expose them, it looks like you have no objects set for export..
With filter and mass edit you can set the export flags to a batch of objects.
