Support on 5500NAC2
SpaceLogic C-Bus Forum
Schneider Electric forum about the C-Bus platform to get support and share knowledge including Network Automation Controller (NAC), Application Controller (AC) at selection, installation and troubleshooting sides.
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic C-Bus Forum
  • Support on 5500NAC2
sesa96364
sesa96364 Schneider Alumni (Retired)
9
KCWong
Lieutenant JG KCWong Lieutenant JG
4
DarrenMullighan
Ensign DarrenMullighan Ensign
1
SJFP
Lieutenant | EcoXpert Master SJFP Lieutenant | EcoXpert Master
1
Back to SpaceLogic C-Bus Forum
Samimul_Islam
Lieutenant JG Samimul_Islam
Lieutenant JG
Posted: ‎2023-09-05 02:27 AM
909
Support on 5500NAC2
Hi
We are System Integrator in Bangladesh. We are working on  a project which we provided C  Bus system in commercial Building. We have supplied Network Automation Controller (5500NAC2) where we are facing some problem we can't master on/off or scene control in single button. We have programmed Toolkit software with DLT switch where one button ON and another button OFF using SCENE command it work properly.  Could you please support how to solve master on/off single switch in Network Automation Controller (5500NAC2) also what will be  Andriod/Apple mobile apps for it?
Regards
Samimul Islam
laurence_crowhu
Ensign laurence_crowhu
Ensign
Posted: ‎2023-09-07 02:00 AM
Firstly I have written an App for both android and apple (note apple apple has a lot more features currently). You will still have to create the UI in wiser.  You can find the links to the apps on my website at crowhurst.com.au. My contact details are also on there.
On the NAC you could create two scenes 1 when of is trigger , 1 when on is triggered. Select the same trigger group for both, but change the action selector eg 0 = off , 255 = on
laurence_crowhu
Ensign
