Schneider Electric forum about the C-Bus platform to get support and share knowledge including Network Automation Controller (NAC), Application Controller (AC) at selection, installation and troubleshooting sides.
Hello community,
Currently, I am working on a hotel room control project. I am having a problem with thermostat,using TC303 series thermostat with model number TC303-3A2DPMS to connect to HRC. The problem I have here is that when connecting 2 thermostats to HRC via RS-485 port, these 2 thermostats will automatically turn on and off ECO mode continuously. I have attached a video of the error encountered in this post. I hope to be able to find the cause and the way to fix this problem.
Thanks for help
I also have the nearly same problem. I connected TC907 to HRC via RS-485. I set the window contact (key card contact) to normaly close. But after few minutes the thermostat change the contact to normally close.
Do you have any solutions for the problem?
Thanks in advance.
