Script Required for 5500SHAC
SpaceLogic C-Bus Forum
Schneider Electric forum about the C-Bus platform to get support and share knowledge including Network Automation Controller (NAC), Application Controller (AC) at selection, installation and troubleshooting sides.
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic C-Bus Forum
  • Script Required for 5500SHAC
sesa96364
sesa96364 Schneider Alumni (Retired)
9
KCWong
Lieutenant KCWong Lieutenant
4
ZeeZee97
Administrator ZeeZee97 Administrator
1
Back to SpaceLogic C-Bus Forum
Posted: ‎2021-10-11 07:39 AM
924
Dear Community Members,
We want to create following scripts in 5500SHAC :
1. Single page to check the status of the lights of all areas which are ON.
2. DND button to override all ongoing time scheduling
3. VRV control through Modbus TSP
4. Alexa voice control in 5500SHAC
Regards
Sanjeev
Coppo
Lt. Commander Coppo Lt. Commander
Lt. Commander
Posted: ‎2021-10-11 04:04 PM
Answer)  If you already have the product,  I'd suggest you do the online scripting course through the AU training team.
https://www.clipsal.com/training-forms-course-listing/c-bus-training-courses/on-line-course-cacsol
Answer) After you complete the training , the Training team will put you intouch with learning materials to support scheduling control via scripting
Answer) You will need to undertake the creation of a suitable JSON for your Hardware, including testing and validating it.
It requires both a 5500SHAC and a live VRV system to preform testing/validating.  SE do not have access to other manufacturers products,  so this typically only happens as large projects occur or SE EcoXperts provide SE Exchange with JSON's they have created and tested on jobs.
To achieve this it would require;
experience with Modbus
experience with JSON files
technical docs from VRV manufacturer with their Modbus register info
5500SHAC
live VRV system that you are trying to integrate to
time to test and debug
Achieving a working JSON can be very time consuming, even with all the above things available.
In some cases it has taken me 1-2 full days for achieiving a valid JSON file.
Answer) nothing available so far from SE business.  Best plan would be for you to write a MQTT plug-in script for 5500SHAC and using Home assistant for integration.  5500SHAC does not support MQTT natively.
