Schneider Electric forum about the C-Bus platform to get support and share knowledge including Network Automation Controller (NAC), Application Controller (AC) at selection, installation and troubleshooting sides.
Power meter Active Energy Meter reached Mega Watts no longer at Kw/hr, now my Modbus register 3256 is reading in accurate value not matching, how may I resolve issue.
If your meter switched from kW/kWh to MW/MWh, update your Modbus scaling: confirm register 3256’s data type (16-bit vs 32-bit float), endianness, and new multiplier (often ×1000 when moving k→M). Recheck the latest register map—some meters change the engineering units register or use a separate register for energy vs power (kW vs kWh). In your SCADA/PLC: set 32-bit float if required, apply the new unit multiplier, and verify by comparing the front-panel value to the polled value.
