BACnet Communication Issue with Multiple 5500NAC
SpaceLogic C-Bus Forum
Schneider Electric forum about the C-Bus platform to get support and share knowledge including Network Automation Controller (NAC), Application Controller (AC) at selection, installation and troubleshooting sides.
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic C-Bus Forum
  • BACnet Communication Issue with Multiple 5500NAC
sesa96364
sesa96364 Schneider Alumni (Retired)
9
KCWong
Lieutenant KCWong Lieutenant
4
ZeeZee97
Administrator ZeeZee97 Administrator
1
Back to SpaceLogic C-Bus Forum
hantsuki
hantsuki
Cadet
Posted: ‎2025-08-17 06:53 PM . Last Modified: ‎2025-08-17 06:54 PM
289
Hello everyone,
I have a project site with 1 unit of LSS5500NAC and 4 units of 5500NAC2, all on the same subnet. Their IP addresses and Device IDs are all different.
When I use YABE to scan, only the LSS5500NAC can be discovered.
I tried restarting the BACnet Server on one of the 5500NAC2 units. YABE can detect it for a moment, but when I click into it, the program freezes.
May I ask if this could be due to some configuration issue?
Tags (2)
  • chinese
Mr_C
Ensign Mr_C Ensign
Ensign
Posted: ‎2025-08-24 04:59 PM
Thanks for raising this issue. To help us support you more effectively, could you please provide a few more details?
  1. Firmware Versions – What firmware versions are currently running on all the 5500NAC  controllers as well as the LSS5500NAC involved?
  2. IP Configuration – What is the IP subnet configuration for the devices?
  3. YABE Behavior – When you say “YABE freezes,” do you mean the application itself becomes unresponsive, or is it a specific controller that stops responding?
  4. BACnet Settings – Could you share the full BACnet configuration settings for the affected devices?
  5. “Detect” Clarification – When you mention “Detect,” are you referring to YABE’s scan function? Does it initially detect devices and then stop? If so, does it always stop at the same point or device?
With this information, we’ll be in a much better position to help troubleshoot the issue.
Schneider Electric Australia PTY
