LUA PAGE (.lp) usage in a frame URL
SpaceLogic C-Bus Forum
Schneider Electric forum about the C-Bus platform to get support and share knowledge including Network Automation Controller (NAC), Application Controller (AC) at selection, installation and troubleshooting sides.
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic C-Bus Forum
  • LUA PAGE (.lp) usage in a frame URL
sesa96364
sesa96364 Schneider Alumni (Retired)
9
KCWong
Lieutenant KCWong Lieutenant
4
ZeeZee97
Administrator ZeeZee97 Administrator
1
Back to SpaceLogic C-Bus Forum
SJFP
Lieutenant | EcoXpert Master SJFP Lieutenant | EcoXpert Master
Posted: ‎2025-06-15 02:57 AM
742
Trying to implement a means logging of various objects that can be used to display information to end user using a frame url /user/logs.lp (last 10 enties) on their Settings Visualization Page.
Noticed in the Logicmachine forum there is coding for eventlog.lp which i have tried on a LM and works fine, but unfortunately doesn't work on the NAC or SHAC.
Think it may be down to require('apps') which may not be included with C-BUS libraries.
Just seeing if there is a work around to active the same in NAC / SHAC devices to that of the LM
Any help would be appreciated.
SJFP
Posted: ‎2025-06-17 11:25 PM
695
Colin, with the help from the guys at LM, we established two files were missing, once copied over from a LM controller and stored in /user/ then modified the original lua page eventlog.lp to point the location of the files to the new location /user/ the page then worked. took a while to sort but there now.
missing files were bootstrap.css and js/jquery
Replies 5
Mr_C
Ensign Mr_C Ensign
Ensign
Posted: ‎2025-06-17 05:45 PM
What is the Firmware Version and also model number of your NAC / SHAC
If the dependency is on Apps
you may require firmware versions 2.0 and above and also ensure that your device is either a 5500AC2 or 5500NAC2
Schneider Electric Australia PTY
SJFP
696
Mr_C
Ensign Mr_C Ensign
Ensign
Posted: ‎2025-06-30 08:49 PM
Thanks, @SJFP
I would like to raise a ticket to have this addressed in our own firmware,
Can you please share additional details as requested. Mainly what Model, and what Firmware version you were working with originally on the controller.
SJFP
Posted: ‎2025-06-30 11:10 PM
628
Details of the controller are
LSS5500NAC (i.MX28) running FW 1.18.0
Mr_C
Ensign Mr_C Ensign
Ensign
Posted: ‎2025-07-03 05:41 PM
@SJFP  Thanks for the details.
Simple Answer to your issues,  is that the files and services you were looking for are not in this version of controller as the models LSS5500NAC  LSS5500SHAC 5500NAC & 5500SHAC are not available with Version 2.0 or Later Firmware,    The Files and Paths you mention only exist in the Firmware and Controllers 5500NAC2 and 5500AC2,   Currently Firmware version 2.1.0 with Apps is present on these devices,
