C-Bus NAC Multiple Networks
SpaceLogic C-Bus Forum
Schneider Electric forum about the C-Bus platform to get support and share knowledge including Network Automation Controller (NAC), Application Controller (AC) at selection, installation and troubleshooting sides.
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic C-Bus Forum
  • C-Bus NAC Multiple Networks
sesa96364
sesa96364 Schneider Alumni (Retired)
9
KCWong
Lieutenant KCWong Lieutenant
4
ZeeZee97
Administrator ZeeZee97 Administrator
1
Back to SpaceLogic C-Bus Forum
SJFP
Lieutenant | EcoXpert Master SJFP Lieutenant | EcoXpert Master
Posted: ‎2019-11-12 12:21 AM . Last Modified: ‎2020-01-31 06:51 AM
2
985
Hi, we have a project using multiple NAC's to control build lighting. One Building has a NAC and 3 bridged networks.
One of these bridges (5500NB) keeps locking out, and has to be reset by unplugging both sides of the A and B connections.
This happened may be 2 to 3 time a year.
So the question is two parts.
1. What would the network bridge to freeze and not allow any communications between the networks. We have replaced the 3 times over the last 7 years.
2. The site use to run on SchedulePlus, but we changed over to using NAC's (LS5500NAC) in each building. With SchedulePlus we could monitor the network states of each building, but how can this be done with the NAC.
Cant see how we can see if a bridge network segment has been lost.
Omaelk
Janeway Omaelk
Janeway
Posted: ‎2019-11-13 03:51 PM
Hey @SJFP  , thank you for your question
I moved your question to the C-Bus forum when the community of experts will be able to provide you the right support and answer your question!
PS: don't hesitate to use the search bar with keywords. there is a lot of content discussed everyday and your issue may have already been solved 😉
Coppo
Lt. Commander Coppo Lt. Commander
Lt. Commander
Posted: ‎2020-09-28 06:51 PM
I have not seen NAC / SHAC "locking out" bridges or heard of it from any other users so far.
You should note that the NAC/SHAC can see where the originating message comes from, so if a message comes from a far network using the same 'GA" back onto your local network...it will be seen as a different object.
If you have common "GA's " across the networks you should create objects for "both the local network "'0" and the far networks to ensure proper control and ststus indication is available.
script can monitor the local network only  for connected, but cannot monitor 'networks connected across 5500NB bridges".
