5500NAC - dimming commands in a script.
SpaceLogic C-Bus Forum
Schneider Electric forum about the C-Bus platform to get support and share knowledge including Network Automation Controller (NAC), Application Controller (AC) at selection, installation and troubleshooting sides.
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic C-Bus Forum
  • 5500NAC - dimming commands in a script.
sesa96364
sesa96364 Schneider Alumni (Retired)
9
KCWong
Lieutenant JG KCWong Lieutenant JG
4
DarrenMullighan
Ensign DarrenMullighan Ensign
1
SJFP
Lieutenant | EcoXpert Master SJFP Lieutenant | EcoXpert Master
1
Back to SpaceLogic C-Bus Forum
Benny_A
Crewman Benny_A
Crewman
Posted: ‎2023-12-09 02:43 AM
I want to handle ramp command and on off command separately in a script.
C-gate dose this very well with separating on/off and ramp commands -but NAC (probably intentionally ) doesn't receive the first dimming command sent out on the bus, set level to 1 for down and 255 for up,
dose 5500NAC run cgate? if so is there a way i can connect to its 20025 port.
i want to achieve an up and a down and stop in a script from a lighting dimming GA on set from an Edlt
i have attempted to use
value = GetCBusRampRate(0, 56, 1)
value = GetCBusTargetLevel(0, 56, 1)
but I still don't see the first command sent by the edlt, it doesn't appear to be processed by the NAC - probably its filtered out and ignored?
Key functions on the eDlt would be super helpful in this situation...
Replies 0
