autotune
  • Industrial Automation
  • Solutions for Motor Management
  • autotune
BJacqz
Commander BJacqz Commander
49
LeoLazzaro
Lieutenant LeoLazzaro Lieutenant
16
PriscilaCunha22
Lieutenant JG PriscilaCunha22 Lieutenant JG
15
Back to Solutions for Motor Management
RuslanK
Crewman RuslanK
Crewman
Posted: ‎2023-05-04 02:02 AM . Last Modified: ‎2023-05-04 02:09 AM
1475
autotune
Hello everyone.
I have ATV630D37N4. And I have motor 7.5 kW. And I want to autotune my frequency converter. But when I start to select engine power i am offered a range 11-55kW. How do I do autotuning in this case?
  • Smart Design & Engineering
Bastian_Schmitz
Admiral
Posted: ‎2023-05-24 02:54 AM
Every VSD has a range in which he works in a proper way. For a 37kW drive it is between 11 and 55kW. You want to use the VSD for a 7,5kW motor. This is out of the scope of this drive. Regarding to this point you are out of the scope of this drive. Neverless if you use U/F the motor should work. If you want to drive the motor in a most efficient way use the matching drive.
Bastian_Schmitz
Admiral
