Posted: 2023-05-23 09:47 AM
I am looking for Dimension and weight details of following APM modules
132 KW(ATV6B0C13Q4), 160 kW (ATV6B0C16Q4)and 200 KW (ATV6B0C20Q4)
Can anyone share it?, I could not get it from available documents
Posted: 2023-05-25 05:48 AM . Last Modified: 2023-05-25 08:14 AM
Just a fast modification on dimensions those seems to be on module only. pleasuse the one as shown on following image :
This size and weight are not considering the incoming cabinet (with circuit breaker, relays, and incoming cables...)
Sorry for convenience
Posted: 2023-05-25 02:52 AM . Last Modified: 2023-05-25 02:52 AM
Hello, the dimension and weight of this product (ATV6B0C13Q4) are as following : 260 kg (573lb) and dimensions are 450x508x1772mm (17.7x20x67.8 in.).
Best Regards
Posted: 2023-05-26 12:52 AM
Thanks!
