FDR won't fire LO1 on TeSys T in Local
  • Industrial Automation
  • Solutions for Motor Management
  • FDR won't fire LO1 on TeSys T in Local
BJacqz
Commander BJacqz Commander
49
LeoLazzaro
Lieutenant LeoLazzaro Lieutenant
16
PriscilaCunha22
Lieutenant JG PriscilaCunha22 Lieutenant JG
15
Back to Solutions for Motor Management
TMS
TMS
Cadet
Posted: ‎2023-04-21 10:26 AM
1407
I have a TeSys T.  I have an FDR attached to it.  IO6 is wired ON for L/R control.
I have SoMove connected to the LTMR simultaneously.
In SoMove IO6 status is ON.
I can change between L/R with the FDR.  In the upper RT corner the FDR says "RDY"
With the FDR in Local, pressing either RUN button does nothing.
In Remote, writing to the 704 bit for Run Forward (0) turns on the LO1.
Why doesn't this work with the FDR?  FDR is set to HMI not Terminals for Local control
  • Drives & Motor Control
  • Soft Starters
Bruno_Hussenet
Crewman Bruno_Hussenet Crewman
Crewman
Posted: ‎2023-05-05 05:29 AM
Hello TMS,
Sorry for the time taken in responding to your request.
My setup : LTMR08EBD V2.9 + LTMCUF (FDR)
With the following settings in SoMove, Input I6 is wired ON  ,  I can change between L/R with the FDR (LTMCUF).
Press button Remote / Local on FDR  then   FDR in Local , press “Run 1”, the motor is running.
At your disposal for any further details.
Regards
Bruno
Jean_Commeignes
Administrator Jean_Commeignes Administrator
Posted: ‎2023-04-27 05:51 AM
Hello TMS, we are looking for the answer...
Best regards
Jean COMMEIGNES
Schneider Electric Community Manager for Power & Building
Bruno_Hussenet
Crewman
Hello TMS,
Regards
Bruno
