Where to find B10d value for TeSys Deca contactors?
  • Industrial Automation
  • Solutions for Motor Management
  • Where to find B10d value for TeSys Deca contactors?
BJacqz
Commander BJacqz Commander
49
LeoLazzaro
Lieutenant LeoLazzaro Lieutenant
16
PriscilaCunha22
Lieutenant JG PriscilaCunha22 Lieutenant JG
15
Bastian_Schmitz
11
Back to Solutions for Motor Management
Posted: ‎2021-11-21 06:06 PM
Step 1: Search the Schneider Electric website https://www.se.com/ww/en/
Step 2: Type the reference of TeSys Deca contactors in the searching bar
Step 3: Go through the datasheet and you will find the B10d value in the "Safety Reliability Level" mentioned in the product specification
Kindly reminder:
TeSys Deca contactors are used for machine and process protection you can rely on to keep people and property safe.
Equipped with integrated mirror contacts, TeSys contactors are designed to provide the self-control features required by the major safety standards.
The TeSys product line also includes all of the isolation, protection, and emergency handling components (circuit breakers and switches with an emergency kill handle, enclosed starters, etc.) you need to comply with the EN 60204-1 and the EN ISO 13850 standards.
  • Products
  • B10d
  • EN 60204-1
  • EN ISO 13850
  • safety
  • Safety Reliability
Replies 0
