Derating Factor
  • Industrial Automation
  • Solutions for Motor Management
  • Derating Factor
BJacqz
Commander BJacqz Commander
49
LeoLazzaro
Lieutenant LeoLazzaro Lieutenant
16
PriscilaCunha22
Lieutenant JG PriscilaCunha22 Lieutenant JG
15
Altivar Process (Medium Voltage)
Back to Solutions for Motor Management
Posted: ‎2021-11-12 07:04 AM
1
2556
Derating Factor
In the ATV6000 handbook, there is a mention of derating factor in case the operating temperature is above 40 degrees. Please suggest if there is any table available to check the derating factor and change in power for the particular drive model.
Gaurav Joshi
ATV6000
  • Products
PriscilaCunha22
Lieutenant JG
Posted: ‎2022-01-12 01:04 PM
Hi!
Derating must be applied on the drive system and the value of the derating is defined by Schneider Services
depending on the customer application and the local environment conditions.
So It's necessary to request this information by project to Drives Team.
PriscilaCunha22
Lieutenant JG
Hi!
