What’s TeSys Giga
  • Industrial Automation
  • Solutions for Motor Management
  • What’s TeSys Giga
BJacqz
Commander BJacqz Commander
49
LeoLazzaro
Lieutenant LeoLazzaro Lieutenant
16
PriscilaCunha22
Lieutenant JG PriscilaCunha22 Lieutenant JG
15
TeSys Giga contactors
Back to Solutions for Motor Management
Posted: ‎2021-11-21 04:39 PM . Last Modified: ‎2021-11-21 04:41 PM
What’s TeSys Giga
TeSys Giga is the new generation high current contactors and from 115 A to 800A in 3 frame sizes and electronic overload relays from 28A to 630A. Contactors are available in 3-pole and 4-pole in standard and advanced versions. Thanks to wide band AC & DC coil control, the complete rage is covered in just 96 product references. Both standard and advanced versions have self-diagnosis feature, with LED function which enables predictive maintenance. TeSys Giga contactors and overload relays are complemented by TeSys Giga GV5 & GV6 Motor Circuit breakers to build complete motor starter solutions.
TeSys Giga CTR G115 G150 G185 G225 G265 G330 G400 G500 G630 G800
Ie (AC-3)/440V 115A 150A 185A 225A 265A 330A 400A 500A 630A 800A
Ie (AC-1)/ 440V 250A 275A 305A 330A 385A 440A 550A 700A 1050A 1050A
LR9G OLR 28…115 A & 57…225 A 125…500 A 160..630 A
  • Products
  • contactors
  • TeSys Giga
Replies 0
