MV Drive Energy savings
  • Industrial Automation
  • Solutions for Motor Management
  • MV Drive Energy savings
BJacqz
Commander BJacqz Commander
49
LeoLazzaro
Lieutenant LeoLazzaro Lieutenant
16
PriscilaCunha22
Lieutenant JG PriscilaCunha22 Lieutenant JG
15
Back to Solutions for Motor Management
BaranitharanGnanamoorthy
BaranitharanGnanamoorthy Cadet
Cadet
Posted: ‎2021-11-15 10:44 PM
2
2007
Hello Team,
what will be the approximate energy savings for 11 kV MV drive for Power plant MV utilities and what is the Payback period (ROI)
Regards
Baranitharan Gnanamoorthy
  • Energy Efficiency
  • MV Drive
Posted: ‎2021-11-15 10:52 PM
You can register here and try out the motor management design tool, which also has features to calculate your savings the same concept with ECo2 if you are using it before...
https://ecostruxure-motor-management.se.app/design/#/
1. Register
2. Navigate the Energy Savings
3. chose the application and field
4. then fill up all information accordingly
5. system can provide you a report.
1. Register
BrownSugar
Lieutenant JG BrownSugar Lieutenant JG
Lieutenant JG
Posted: ‎2021-11-16 01:10 AM
Thank you for the question
