Posted: 2024-04-03 03:56 AM
I want to know about the ports R1A, RIB, R1C in ATV310 VFD. I have seen it in the manual its telling that R1A is NO, R1B is NC and R1C is Common and I want to know where exactly i can use this and its function
Posted: 2024-10-31 06:51 AM
Relays in Altivar drives can be used for various purposes such as controlling external devices like contactors, signaling the drive status, interlocking with other equipment, or triggering alarms. They are commonly used for applications requiring simple control signals or for interfacing with other electrical components in the system.
