Hot Swapping Communications Adapters on ATV320 Drives
  • Industrial Automation
  • Solutions for Motor Management
  • Hot Swapping Communications Adapters on ATV320 Drives
BJacqz
Commander BJacqz Commander
49
LeoLazzaro
Lieutenant LeoLazzaro Lieutenant
16
PriscilaCunha22
Lieutenant JG PriscilaCunha22 Lieutenant JG
15
Back to Solutions for Motor Management
PeteSteelcase
PeteSteelcase
Cadet
Posted: ‎2024-10-11 07:52 AM
621
We have a number of ATV320 drives that connect to the PLC VIA CAN.  We need to do backups with SoMove.  Currently we disconnect the CAN cable, switch the drive to Modbus, power the drive down, power the drive up, back up the drive, switch the drive to CAN, power down the drive, power the drive up, then re-connect the CAN cable.
I would like to use the VW3A3600 mechanical adapter and the VWA3616 Ethernet IP Option Card.  Can these be hot swapped for backing up the drives?
  • Technical Support and Troubleshooting
Bastian_Schmitz
Admiral
Posted: ‎2024-10-17 05:18 AM
The Communcation cards are not designed for hot swap. But in your case you could built an adapter to split the CAN signal from the RS485 Signal. In that case you could use both together. CAN for your communication and RS485 for SOMOVE.
Bastian_Schmitz
Admiral
